FRP Bypass Solution For Android Pie 9.0 Android P FRP bypass via Combination firmware Required tools for unlocking FRP 9.0 android p Combination firmware from -> http://combinationfirmware.com/ Samsung firmware from -> https://pangu.in/samsung-firmware/ Samsung Odin3 3.12 -> https://pangu.in/odin-3-12-3-samsung...amsung-device/ First shut Down the device and put the device into download mode to put the device into download mode you have to press and hold the Bixby key volume down key and Power keys together Now press the volume UP button to continue install the Samsung*USB driver before starting the process you can download the latest driver from above. Now insert the USB type C cable into locked Samsung*device Open Odin and select the Combination file into AP field. Now click on Start Button to start flashing After the flash,*go setting and select the developer mode and enable the USB Debugging option. And flash the stock firmware Now the Samsung*firmware has been unlocked |
this files can support samsung j730g 8.1.0, |
do not stick CP :) |
Are you saying simply flashing combo and enable adb then reflash stock will remove frp? |
thats exactly what its doing.. nothing new at all lol Quote:
