G532f not enter in recovery mode :( Hello, Grand prime + phone have pattern lock issue tried vol + - home- power on but no working is any special method for it ? need hard -reset |
Problem solved with full flashing Code: <ID:0/129> Added!! |
Keep more time the buttons pressed. In the G532m is the same. Try many times and keep always the buttons pressed, dont release. |
Download from here & do you flash with correct regional firmware https://www.androidfilehost.com/?w=files&flid=133308 |
press v+- with conect cabe usb |
problem solved after full flash with same version but its hard to download 1.xx gb file for hard reset only :mad: is any way to make hard reset file like this ? :confused: |
Quote message in reply? |
in this case u need full flash file but flash only user data with z3x and pattern will be removed. |
Check button if not working |
volume down button not working- hardware problem change new volume down button tested, |
it worked for me just connect usb cable then pres vol+ home button+power |
thank you it real worked for me@bikyo |
you can try z3x box ..connect usb cable and open z3x..reboot to recovery |
Perfect solution GUljee:) |
