Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 02-16-2018, 23:39   #1 (permalink)
Member: 2812200
A5 2017 without imei and baseband
Hi! I have a big problem with my a5 2017. I lost the IMEI and the baseband/modem. Solutions?
When I write in the dialer * # 06 # I do not get the word IMEI. Only the serial number and its sequence. No trace of the imei
Old 02-17-2018, 11:38   #2 (permalink)
2201's Avatar
Member: 2639338
Thanks Meter: 133
Flash repair firmware with 4files, latest version and ur baseband will be back.... post model then i can give u ur firmware
Sent from my SM-T531 using Tapatalk
Old 02-17-2018, 13:44   #3 (permalink)
Member: 2812200
[QUOTE=2201;12971741]Flash repair firmware with 4files, latest version and ur baseband will be back.... post model then i can give u ur firmware
Thanks for your help my model is A520F
Old 02-17-2018, 13:54   #4 (permalink)
Member: 1228830
Thanks Meter: 15
If you did not succeed with this flash version A520FXXS4BRA1 ..
Old 02-17-2018, 18:00   #5 (permalink)
Member: 2812200
Full flash or only ap?
Old 02-17-2018, 18:15   #6 (permalink)
Member: 2812200
well... the recovery say this:
failed map file.
Pd:Same situation,without baseband
Old 02-17-2018, 19:51   #7 (permalink)
Member: 2731873
Thanks Meter: 2
your efs folder is probably damaged or deleted i don't think a simple flash of stock rom will fix this in some rare cases it does. I'm currently experiencing the same situation with G950W
The Following User Says Thank You to Darlinx For This Useful Post:
Old 02-17-2018, 21:33   #8 (permalink)
Member: 2812200
omg ... If you were to find a solution, could you share it with me? I will be very grateful
Page generated in 0.19852 seconds with 8 queries
