G920F and A520F on andriod 7.0 FRP Problem Help!! :( Hi everyone i need some help i have a few phones im stuck with G920f and a520f on andriod 7.0 i have tried to flash sboot enable adb but carnt remove lock so i flash combination which gives me factory binary but is on andriod 6.0.1 does this have to be combinayion 7.0? becuase when i use z3x or gsm flasher frp removel tool all i get is USERDATA.IMG is been used by another process..do i have to downgrade to 6.0.1 if so what if i carnt? also sometimes when i try and flash stock odin gives HIDDEN then fails thanks |
Many ways to solve your problem If you want to use combination procedure Which can be applied as a general solution Flash full combination which by the way should be the same binary as the phone ex: (a520fxxu2 ) then 2 is the binary level of which the combination should be No matter 6.0.1 or 7.0 After the phone boots up . Flash stock firmware of the same binary ofcourse but with z3x flash ignoring userdata,pit,hidden And using homeCSC file The phone will boot up know with no setup now go to setting and reset phone. You are done |
Hi, thanks for the kind reply i will try this also when i flash factory then flash firmware sometimes some files remain i.e sticks on sdamsung logo and also download mode has loads of yellow n green writeing like some of the combination files still in there. i have tried flashing the same way before but lock remains on thanks |
Concerning the writings in the download mode its a normal thing especially in new devices such as note8, s8, and s8+ so dont worry For the phone to boot up after flashing stock firmware coming up from combination will take some time 2 or 3 min. Try to choose close versions of combination and firmware to avoid being held on samsung logo Be carefull to not flash userdata, pit so that the phone will not be resetted So you are supposed to flash ( sboot, boot, system ,recovery , modem) This will be enough |
Hi, thanks for your reply.. ok so i have flash comb and then looked through the stock but there is no userdata in any of the folders. i have to delete hidden and flash just the cache of the home csc as it fails i dont know y. pretty new at this but im quick at learning |
4 files firmware will have userdata and pit If it fails at cache remove it |
you are a star ty so much |
Here you got tutorial with links to combination files that you need. SAMSUNG G950F Galaxy S8 - Frequently Asked Questions about resetting your device - HardReset.info |
I have another problem i have a samsung galasy s6 edge removed frp via combination i then download latest firmware and installed it prob is its andrion 7.0 i have had to root it cos it said something about been dirty so had to root it to fix drx error its sim locked and no box will unlock it z3x does not show imei or the csc and *#06# does not bring up the imei any advise please |
Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G928F Timezone: Europe/London Android Version: 7.0 [NRD90M] Build Date: Thu Jan 4 11:57:08 KST 2018 PDA Version: G928FXXS4CRA1 [january 2018, rev1] Phone Version: G928FXXU4CRA1 [january 2018, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: R58H12YGF1D |
Downgrade your modem and then retry to unlock Only downgrade the modem by flashing modem file from older firmware |
Checking hash file... OK Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G928F Android version: 7.0 Product code: SM-G928FZKAEVR Phone version: G928FXXU4CRA1 PDA version: G928FXXS4CRA1 CSC version: CSC country code: CSC sales code: HW version: MP 0.500 Phone S/N: R58H12YGF1D Modem board: SHANNON333 RF cal date: 20160123 IMEI: tried 3 diff cp files nothing works imei does not show on screen |
https://mega.nz/#!oV0n0YJT!rfPhhdPi1...qoJxt928FrVcbg Try this modem |
Mean imei damaged only cert write can help. Org imei is lost if you do not have backup. |
