Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
10-29-2016, 07:28 | #1 (permalink) |
Major Poster Join Date: Oct 2016
Member: 2640279 Status: Offline Thanks Meter: 3 | remove google account from android 6 i need verry lot and searchinhg for a program or a way for remove google account of samsung android 6 like bypass for android 5... thanks for your help and your guids.... |
10-29-2016, 07:33 | #2 (permalink) | |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | Quote:
2.Download and copy com.rootjunky.frpbypass-1.0.apk to the device micro sdcard or download once into the device. 3.Start phone and connect to WIFI also plug into the computer with your usb cable. 4.Start RealTerm on your pc and under pisplay check the box HALF DUPLEX 5.Right click on my computer and select manage once it opens click device manager then modems 6.Under modems you should see a Samsung device. right click it then select properties 7.Once the properties window opens select modem tab and see what port it is on like com5 for an example 8.Now that you know the com port number close all device manager windows and open RealTerm again 9.Under the ports tab in RealTerm enter your port number then click change. 10.Next, click the send tab. you will need to send these two commands with the Send ASCII button 11.First at+creg?\r\n 12.Then atd1234;\r\n 13.Look at your phone and the dailer will pop up press thanku button if u like | |
The Following User Says Thank You to Asad ali khan For This Useful Post: |
10-29-2016, 08:30 | #3 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 727810 Status: Offline Sonork: 100.1627301 Thanks Meter: 167 | yes realterm works on google 6 version , but in latest build you wont found google id & password option in google account manager , this method is also failed for new method , i am also looking for some by pass , as i have paid tools for frp like U.M.T is doing good so far |
11-03-2016, 14:29 | #4 (permalink) | |
Member: 2640279 Status: Offline Thanks Meter: 3 | hi Quote:
The Following User Says Thank You to padideh hamrah For This Useful Post: |
11-04-2016, 06:53 | #6 (permalink) | ||
No Life Poster Join Date: Apr 2016
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | bro its commands for realtream, 1st command at+creg?\r\n and 2nd command atd1234;\r\n ____________________ for better guide see the @xx0o0xx video , its explain every thing to you Quote:
Quote: | ||
11-04-2016, 08:44 | #7 (permalink) | |
Member: 2640279 Status: Offline Thanks Meter: 3 | Quote:
i really need to your help for this problem... | |
