Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 07-15-2019, 12:06   #1 (permalink)
Member: 448264
Thanks Meter: 78
Galaxy J400F Binary U4 FRP Bypass help
with sim pin not work
The Following User Says Thank You to juve2106 For This Useful Post:
Old 07-16-2019, 15:09   #2 (permalink)
Mobile-Lab's Avatar
Member: 10028
Sonork: n/a
Thanks Meter: 840
http://forum.gsmhosting.com/vbb/13738163-post83.html
The Following User Says Thank You to Mobile-Lab For This Useful Post:
Old 07-16-2019, 20:07   #3 (permalink)
Crazy Poster
Member: 869660
Thanks Meter: 14
1.Put pin locked nano sim inside phone in sim 2 socket(make sure you know the pass)
2. once phone on move sim little up so that lock screen goes away
3. connect wifi
4. put sim in correct place so that phone asks for code again
5. just before phone asks for code keep sliding the notification pannel quickly several times so that it gets stuck in lock screen
6. once you see notification and pin lock screen together
7. put pin code 1234 or 0000 and do not press ok
8. hold phone in landscape mode and quickly tap on notification setting and tap ok with other finger
9. if success you will reach notification settings
10. open youtube in app notification and reach till chrome install android 8 gam and frp bypass put gmail id reboot and remove account do not reset
The Following 4 Users Say Thank You to bikelover1352 For This Useful Post:
Old 07-23-2019, 14:54   #4 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,437
Sorry, it does not work on J400FXXU4BSF4.
Tried several times without success
Old 07-23-2019, 18:16   #5 (permalink)
Crazy Poster
Member: 869660
Thanks Meter: 14
tried in 4 sets working no issues
Old 07-23-2019, 20:07   #6 (permalink)
saifulhaq28's Avatar
Member: 1902758
Sonork: 100.1680534
Thanks Meter: 152
binary u4 does not work in this method...
Old 07-24-2019, 14:58   #7 (permalink)
Member: 2401943
Thanks Meter: 182
3. connect wifi
not work ; j415f u4 ... any other solution ?
Old 07-26-2019, 12:16   #8 (permalink)
Member: 2491939
I did try but not working pls help
Old 07-26-2019, 13:17   #9 (permalink)
Member: 2613252
Thanks Meter: 1,837
Hello, use new method smart switch
All SAMSUNG FRP/Google Lock Bypass Android 9 WITHOUT PC | NO SIM PIN | NO TALKBACK - NEW
https://m.youtube.com/watch?v=1ydqy3Nur3w&t=554s
The Following User Says Thank You to amleto90 For This Useful Post:
Old 07-26-2019, 14:52   #10 (permalink)
Member: 2491939
Idid try already this method but not done I need tested solution
Also need this model u4 combination firmware
Sent from my Redmi Note 3 using Tapatalk
Old 07-27-2019, 11:01   #11 (permalink)
Crazy Poster
Member: 594103
Thanks Meter: 44
Free Downlaod
SM-J400F binary U4 Combination file for frp
http://shafiqjees.ga/2019/07/27/sm-j...-file-for-frp/
The Following User Says Thank You to imranquresh For This Useful Post:
Old 08-05-2019, 19:13   #12 (permalink)
Abussabah's Avatar
Member: 412813
Sonork: 100.1594692
Thanks Meter: 353
http://www.youtube.com/watch?v=lRmJVDt4I74&t=407s
bypass 100% ok
The Following User Says Thank You to Abussabah For This Useful Post:
Old 08-08-2019, 21:55   #13 (permalink)
Mobile-Lab's Avatar
Member: 10028
Sonork: n/a
Thanks Meter: 840
All SAMSUNG AUGUST 2019 FRP/Google Lock Bypass Android 9 WITHOUT PC
http://forum.gsmhosting.com/vbb/13774028-post84.html
Old 11-04-2019, 09:08   #14 (permalink)
Member: 2475109
Thanks Meter: 140
new security J400f FRP bypass solved
Download combination file COMBINATION_FAC_FA80_J400FXXU4ASG1_FACFAC_CL136731 63_QB24605504_REV00_user_mid_noship.tar
Unlock OEM from setting then flash with official firmware j400fxxu4bsf4
step by step video guide on how to disable and bypass j400f FRP 9.0/9.1
http://www.youtube.com/watch?v=/8CTwmdeREdo
How To Flash
Page generated in 0.22242 seconds with 8 queries
