Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 03-06-2018, 06:52   #106 (permalink)
Registered User
Member: 749179
Sonork: 100.1668876
Thanks Meter: 68
Originally Posted by MISHUK_SIKDER View Post
model G532f
COMBINATION flash fail. now what can i do?
i m done with great tutorial . for COMBINATION flash fail try another combination file i m tasted.
Old 03-18-2018, 17:32   #107 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
According To instruction ,
Solution Worked Perfectly
Thanks! Alot
Old 03-18-2018, 19:41   #108 (permalink)
Member: 220595
Thanks Meter: 355
People nobody has signal or registration problems?
Enviado desde mi SM-G930F mediante Tapatalk
Old 03-20-2018, 07:19   #109 (permalink)
Member: 2438408
Thanks Meter: 380
g532g supported?????????????
The Following User Says Thank You to alexid For This Useful Post:
Old 03-23-2018, 13:21   #110 (permalink)
Member: 134165
Thanks Meter: 2
flash file are g532f and combination file is g532g it works or not
Old 03-31-2018, 09:31   #111 (permalink)
Member: 2045788
Sonork: 100.1663155
Thanks Meter: 28
SM-G532F-ROOT_KERNEL FIRMWARE_FOR-ROOT
Sir can i use this file for G532G
If not plesae give me G532G ROOT_KERNEL FIRMWARE
please help me
Old 04-12-2018, 15:36   #112 (permalink)
Member: 2775839
Sonork: 100.1662560
Thanks Meter: 25
please g532g after repaer boot imei wrong
Old 05-05-2018, 14:14   #113 (permalink)
Member: 2632358
Sonork: 100.1651248
Thanks Meter: 2
sir can you have same like solution for samsung g570f j5prime
Old 05-12-2018, 17:53   #114 (permalink)
Member: 431502
Thanks Meter: 2
Sm-g532f-root_kernel firmware_for-root
pls code rar
Old 05-18-2018, 07:46   #115 (permalink)
Member: 2772262
Sonork: 100.650600
no luck bro...first wicht crt ok z3x ..ime ok but it.s show emarncy call...than i try wipe sekority...now basebend gone
Old 05-25-2018, 09:13   #116 (permalink)
Member: 2739178
Thanks Meter: 2
if your samsung G532f network is not working flash efs file dont change imei network will work again :-)
Old 05-25-2018, 09:33   #117 (permalink)
Member: 2739178
Thanks Meter: 2
just root phone and download a working efs file flash it with odin no need to change the imei number or flash cert
working 100% tested
The Following 2 Users Say Thank You to BoiToxic For This Useful Post:
Old 05-25-2018, 10:32   #118 (permalink)
Member: 2226476
Plz Help I have Samsung J5 Prime (G5700) Last FRP Lock. Plz Help Me?
Old 05-26-2018, 16:30   #119 (permalink)
Member: 2590829
Sonork: cvbchhj
Thank you very much. This methot working. Good job..!!!
Old 05-27-2018, 04:30   #120 (permalink)
Member: 2695594
Pls help g532fd ime ok sim showing, but showing emergency no patch certificate on z3x ..... Pls hw can I fix this.... Thanks 🙏 in advance
Page generated in 0.21924 seconds with 9 queries
