Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
04-10-2013, 11:07 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Philippines
Member: 752151 Status: Offline Thanks Meter: 211 | [ Guide ] N7100 Note 2 / i9300 S3 " Easy " Boot Repair swich . Uploaded with ImageShack.us how to make bootloader recovery for n7100. to follow.. |
The Following 20 Users Say Thank You to tantan167 For This Useful Post: |
04-10-2013, 21:34 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Good Work Bro Small Update From my Side , This Swich Also Use For i9300 Boot Reapir Br |
The Following 3 Users Say Thank You to Mohsin-* For This Useful Post: |
04-17-2013, 21:06 | #6 (permalink) |
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Hello Please check sticky Threads , its updated http://forum.gsmhosting.com/vbb/f777...e-2-a-1644940/ Hello Please check sticky Threads , its updated http://forum.gsmhosting.com/vbb/f777...e-2-a-1644940/ file updated on Sticky . what more Steps u need >? already available for i9300 and now updated N7100 here http://forum.gsmhosting.com/vbb/f777...e-2-a-1644940/ Br |
04-22-2013, 12:29 | #7 (permalink) |
No Life Poster Join Date: Feb 2001 Location: PH
Member: 3468 Status: Offline Thanks Meter: 308 | Hi i have note2 no power and i try repair boot always stock on "COPY BINARY FROM SDCARD.. COPY BINARY TO EMMC.." any help? |
The Following User Says Thank You to Rex For This Useful Post: |
04-22-2013, 23:01 | #9 (permalink) |
Member: 752151 Status: Offline Thanks Meter: 211 | This is my problem before. No software solution as of now. Until now i'm using hardware solution. Uploaded with ImageShack.us No available EMMC for N7100 already have program in my place right now, only i9300 emmc are available. i'm using i9300 emmc (new) for n7100, just put bootloader recovery from n7100. Q: How to make bootloader recovery for n7100? A: Same procedure like i9300. Q: Why no LCD display but have sound after put the new EMMC? A: Now do the bootloader recovery procedure (Up picture). After that the display is appear. After Finish, now you can download the N7100 firmware. Uploaded with ImageShack.us Sorry for my English... Use your logic. |
04-22-2013, 23:22 | #10 (permalink) |
Insane Poster Join Date: Feb 2011 Location: Saudi Arabia
Member: 1522831 Status: Offline Sonork: 1603358 Thanks Meter: 28 | samsung galaxy S3 I9300 dead sir i have I9300 dead i run same this method but no screen show SDCARD DOWNLOAD COMPLTED just show screen SDCARD MODE COPY BINARY FORM SDCARD.. COPY BINARY EMMC.. - This Document cannot be used without Samsung’s Authorization - Published By [ Global CS Team in HQ] ※ This Service Bulletin is a property of Samsung Electronics Co.,Ltd. Any unauthorized use of Bulletin can be punished under applicable International and/or domestic law. Confidential Notice 84 Product GSM Notice No. 12-38 Model Galaxy S3(GT-I9300#) Notice Date 4 th Jun ’12 Subject JTAG Guide Scope Subsidiary ( Yes ) ASC ( Yes ) Customer ( No ) 1. Purpose - To inform All ASCs of information about Technical Tip. 2. Instruction - Brief JTAG process for GT-I9300 1) Copying JTAG(bootloader) file to external SD Card, using normal GT-I9300. 2) inserting the SD card to ‘No Power’ phone, and copy the bootloader file to the defective PBA. 3) After downloading bootloader file to the defective phone, enter the download mode with the phone, and download Full S/W.(PIT, PDA, CSC, PHONE files) - Pre-requisite 1) One normal I9300 phone(normally booted on) 2) External SD Card (Memory size should be 2GB or bigger.) 3) Odin3 v3.07.exe and Odin3.ini (uploaded on HHPsvc > Find Content > Download PGM > GT-I9300 4) GT-I9300_Boot_Recovery.tar (uploaded on HHPsvc > Find Contents > J-TAG Program > GT-I9300 - This Document cannot be used without Samsung’s Authorization - Confidential - Detailed JTAG Process 1) Insert External SD Card to normal phone to copy Bootloader to SD card. 2) Run Odin3 v3.07.exe 3) Click ‘Bootloader’ button and load “GT-I9300_Boot_Recovery.tar”. Published By [Global CS Team in HQ] - This Document cannot be used without Samsung’s Authorization - Confidential 4) Enter download mode with the normal phone(SD Card inserted). ※ Download Mode : Volume Down key + Home key + Power Key and press Volume Up key. Published By [Global CS Team in HQ] 5) Connect the phone to PC, using USB cable. < Volume Down key + Home key + Power Key > Volume Up < Download Mode > - This Document cannot be used without Samsung’s Authorization - Confidential 6) Click Start button to copy bootloader to the phone. Published By [ Global CS Team in HQ] 7) Disconnect the phone from PC. 8) Close the Odin3 v3.07.exe and Run it again. - This Document cannot be used without Samsung’s Authorization - Confidential 9) Click ‘Bootloader’ button and load “GT-I9300_Boot_Recovery.tar”, And check ‘T Flash’ option in the Odin, to copy bootloader to SD Card. Published By [ Global CS Team in HQ] 10) Enter download mode with the normal phone(bootloader was copied before), and connect it to PC again. - This Document cannot be used without Samsung’s Authorization - Confidential 11) Click Start button to copy bootloader to the SD Card. 12) After downloading, turn off the phone and remove the SD Card. → This SD card will be used to recover boot of the phone. 13) Disassemble the ‘No Power’ phone, but connecting the LCD with PBA, to check the LCD if boot recovery is successfully done. Published By [ Global CS Team in HQ] - This Document cannot be used without Samsung’s Authorization - Confidential 14) Insert SD card(bootloader was copied) to the PBA. 15) Connect the PBA with Anyway JIG and power supply, with the POWER OFF. ※ Use 11pin cable to supply power to the PBA. Published By [ Global CS Team in HQ] - This Document cannot be used without Samsung’s Authorization - Confidential 16) Short R313 resistance.(HQ uses tweezers to short the resistance) Published By [ Global CS Team in HQ] - This Document cannot be used without Samsung’s Authorization - Published By [ Global CS Team in HQ] Confidential 17) Turn on the PBA, and REMOVE THE SHORT between 3 to 6 seconds from turning on the PBA. 21) Download Full S/W including PIT, PDA, CSC and PHONE.18) After approximately 5 seconds, you can see message on the LCD boot recovery was succeeded. 19) Turn off the pba, and remove SD Card. 20) Assemble the phone, and enter download mode. |
05-01-2013, 23:22 | #13 (permalink) |
Member: 752151 Status: Offline Thanks Meter: 211 | |
The Following User Says Thank You to tantan167 For This Useful Post: |
05-02-2013, 11:50 | #14 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: India
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Quote:
Dear Member... is there any other way to give power to phone, if we dont have Anyway JIG.... Because when i connet downloader JIG to phone, the phone gets power before shorting the component in I9300... | |
05-02-2013, 21:27 | #15 (permalink) | |
Member: 752151 Status: Offline Thanks Meter: 211 | Quote:
put jig, then short r313. put the battery, after 7 second remove or release the short. | |
