[Guide] Samsung Galaxy Series Phone Camera Failed / Error problems Solution Some times your Samsung galaxy Series phone’s Camera app has got itself into a bit of mess. Most of Camera failed message come because of this case. So, you have to refresh it. To refresh, Fix Camera Failed on Samsung galaxy Code: Go into Settings How To go Safe Mood Code: 1.Turn Off the phone by pressing power. We have dedicated Wiping Cache posts. camera Failed on Samsung galaxy Code: Wipe cache on Samsung galaxy phone Update Software Code: Update is more important thing when using a smartphone. If this is a error Of android OS then Next Update come with Fixed that. Factory Reset Samsung galaxy Phone Code: Above methods didn’t help? Then Reset your phone. that means, Restore your phone to Factory Setting. and This cause to Lose all DATA on phone.So, Reset my phone or Hard reset Code: 1.Turn off the phone. Flash a Stock ROM on Samsung galaxy Phone Code: All above methods didn’t help? then This is the last one..When you face this kind of problem in computer, like virus affection badly or system error, then your last method is Installing Windows again. I Flashed a Stock Rom, now Camera failed. Code: That means your current Rom is Corrupted or damaged. Now you have to Install Stock Rom to ON your phone. Camera needs restart Code: Most of time this is a error of hardware. you had better install stock rom. |
try to clear cachce and then try again hope this will work for you. |
hi and how are you bosss. i have a customer phone samsung s7 and the camera focus doesnt work. i tried all the steps you mentioned above. none of them doesnt make the camera auto focus. finally, i decided to replace rear camera and now it gives me message ( camera fail) front and rear. new rear camera installed, i factory reset, wiped cache and all of the steps agian and it doesnt work. any solution please |
Please check your camera, your old camera h/w & new one everything is same? If you already checked that's part of camera related everything. Post result |
Samsung j210f camera error 100% solved I keep this thread with camera problem related thread. http://forum.gsmhosting.com/vbb/f777...olved-2210935/ |
samsung j200G front camra not workin after reset 100% solution |
