[Guide] Samsung GT-I9100G - usb boot repair download link phone mustbe off connect phone without battery and use usb_drv_windows this driver than run this bat file omap4430hs_espresso_1200MHZ and wait 20 30 sec phone will aliwe again |
i think this same way to repaired samsung i9250 phone anyway good job |
samsung I9100G cpu change from samsung i9100? |
Seems that now end user can rescue their phone by them self now. we prepare to sell our jtag box :D |
Now I tested At I9100G Dead Booted AND Finally Not Work :confused: BR, BEHBOODI |
Code: Driver configuration: rpapi_base = 0x00028400 :rolleyes: BR Asangsm team |
I have a dead i9250m galaxy nexus Below I will copy the result of the tool..when I use the tuna one the omap connects and disconnects quickly..when i use the one for i9000 the omap stays connected longer..I think i need different configurations some how..any hep would be appreciated..been trying to deal with this issue for some time: I will copy the tuna log below where the one for i9000 no second found and i tried to use other seconds no luck: » OMAPFlash v4.15 (Aug 12 2011) » -v » Entering parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.txt at line : 1 » -omap 4 » -t 36000 » -p OMAP4460_TUNA_8G_HS_PRO » -2 » -rxtx_trace » chip_download EMMC Targets\Projects\tuna\MLO_4460_HS_PRO » chip_download EMMC Targets\Projects\tuna\sbl.img » command cold_sw_reset » Leaving parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.txt » @Targets\Projects\tuna\omap4460_tuna_hs_pro.txt » Looking for device (omap usb) » Please turn on device » Waiting for device (omap usb) » Found device (omap usb) » Requesting ASIC id 00130-000-TX 4 raw bytes: 03 00 03 F0 '????' » AsicId items 05 » AsicId id 01 05 01 44 40 07 01 » AsicId secure_mode 13 02 01 00 » AsicId public_id 12 15 01 97 1E D2 40 84 FC E8 16 AA 20 26 62 0C 90 E0 83 26 88 80 7B » AsicId root_key_hash 14 21 01 67 98 9B 35 54 CC 86 B4 67 32 47 05 36 74 E2 25 F0 9D A3 5C F4 59 B9 C9 3A 13 E0 B9 58 1E 5A BC » AsicId checksum 15 09 01 22 9E 85 BA DC 58 74 BC 00130-001-TX 4 raw bytes: 02 00 03 F0 '????' » Searching 2nd for: OMAP4460_TUNA_8G_HS_PRO 444007 01 HS » Loading second file Targets/2nd-Downloaders/dnld_startup_omap4_hs_8g_es2.s2.si gned.2nd.hs_pro » Entering parameter file:omapflash2nd.txt at line: 46 » -pheriphalboot_reopen » Reading board configuration file Targets\Configurations\configuration_omap4460 _tuna_8g.txt » Reading definition file .\targets\definitions\definitions_omap4.txt » -board_config Targets\Configurations\configuration_omap4460_tuna_8g.txt » Leaving parameter file:omapflash2nd.txt » Sending size of second file (0x000071B0 bytes) 00130-002-TX 4 raw bytes: B0 71 00 00 '?q??' » Transferring second file to target (0x71B0 bytes) 00130-003-TX 29104 raw bytes: B0 1C 00 00 00 4D 00 00 00 00 00 00 00 00 00 00 '?????M??????????' ... » Closing boot connection » Waiting for device (omap usb) » Found device (omap usb) » Waiting for 2nd 00463-004-TX ACK 00571-005-RX: 4 raw bytes: 70 EC 8F 00 'p???' » Unknown status message 'p???' during peripheral boot (waiting for 2nd) Press any key to continue . . . -------------- thanx for your support..I posted on the main post by ligejja and got no help there.. |
this is not work for me |
@ ...:::JamalMustafa:::... Hey...! Your link is Broken.. Plz Check link. |
thx all i repair boot but phone not flash what the of flashing ???? |
this a problem |
this is not work for me logo draw failed |
i have same problem logo draw failed |
