Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
![]() | #35 (permalink) |
Banned ![]() ![]() ![]() Join Date: Aug 2005
Member: 172448 Status: Offline Thanks Meter: 5 | Tnx mr R3iS , finally after about 6 months phone back to life ![]() but this tool write Locked chinese bootloader (locked sbl) and we have to write only chinese FW and i tried to write other fw from other countries such as indian , thailand ,France but all time odin failed to write this three files : MLO , SBL , MODEM . Do u have unlocked bootloader (SBL) to unlock boot ?? tnx . |
![]() | #36 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,258 ![]() | with out Battery Program Run ok and Repair Done ,but nothing on LCD With Battery i able see Download Screen but Phone Stuck there no Ask drivers ETC , can any one Help in Repair ? |
![]() | #43 (permalink) |
Junior Member Join Date: Apr 2007
Member: 486988 Status: Offline Thanks Meter: 1 | Complete Instruction 100% Working 0. Download the tool OMAPFlash_1229_2ndlastt from the first post and extract it somewhere. 1. Get your firmware from **************. it will be an *.tar.md5 file. make a copy of the *.tar.md5 file and rename to *.tar file. 3. open the tar file with winrar and extract "MLO" "param.lfs" and "Sbl.bin" and keep somewhere. 4. Now go to the downloaded OMAPFlash_1229_2ndlastt\Targets\Projects\espresso folder copy and replace "MLO" "param.lfs" and "Sbl.bin" with files extracted earlier. 5. Take the battery off the phone. connect the phone with pc while keeping windows device manager opened. Omap4430 will be shown for a second or two. double click quickly on that and from properties update the driver with windows driver provided in OMAPFlash_1229_2ndlastt 6. after driver is installed, disconnect phone from pc and run omap4430hs_espresso_1200MHZ.bat. it will prompt you to connect the phone. 7. connect the phone and the repair will be done in 30 sec and it will say "waiting for device". Now disconnect the phone and insert the battery but do not turn on. 8. now insert a USB Jig and phone will immediately go to download mode. 9. As you have already replaced "MLO" "param.lfs" and "Sbl.bin" with your choice of firmware files it flash like dream Enjoy your resurrected I9100G!!!! |
The Following User Says Thank You to khmahbub For This Useful Post: |
![]() | #44 (permalink) |
Junior Member ![]() ![]() Join Date: Jul 2007
Member: 556452 Status: Offline Thanks Meter: 1 | ![]() Will this work on a Galaxy Note GT - N7000 ?? The rom at the time was 4.0.4 kies update. To cut a long story short.... I used odin on the pc and flashed (by mistake) the wrong bootloader into the phone! ![]() So now.... Basically when I press power on the phone, nothing happens. When I put the 'jig' into it - nothing happens - no download mode when I press the recovery key / download key modes - nothing happens When I plug the charger in - there is no battery charge icon Basically the phone is bricked and having read this thread on how to revive a Samsung without the phone having to be turned on, or the battery in, well I thought to ask. Many thanks for any replies. |
![]() | #45 (permalink) | |
Junior Member Join Date: Aug 2012
Member: 1796712 Status: Offline Thanks Meter: 0 | Quote:
'logo.jpg' draw failed... again Code: eMMC CID PSN = 0x00001F49 // Product serial numbe r eMMC CID MDT = 0x1F // Manufacturing date eMMC CID CRC = 0x24 // CRC7 checksum eMMC CSD CSD_STRUCTURE = 0x03 // CSD structure eMMC CSD SPEC_VERS = 0x04 // System specification version eMMC CSD TAAC = 0x27 // Data read access-tim e 1 eMMC CSD NSAC = 0x01 // Data read access-tim e 2 in CLK cycles (NSAC*100) eMMC CSD TRAN_SPEED = 0x32 // Max. bus clock frequ ency eMMC CSD CCC = 0x00F5 // Card command classes eMMC CSD READ_BL_LEN = 0x09 // Max. read data block length eMMC CSD READ_BL_PARTIAL = 0x00 // Partial blocks for r ead allowed eMMC CSD WRITE_BLK_MISALIGN = 0x00 // Write block misalign ment eMMC CSD READ_BLK_MISALIGN = 0x00 // Read block misalignm ent eMMC CSD DSR_IMP = 0x00 // DSR implemented eMMC CSD C_SIZE = 0x00FF // Device size eMMC CSD VDD_R_CURR_MIN = 0x06 // Max. read current @ VDD min eMMC CSD VDD_R_CURR_MAX = 0x06 // Max. read current @ VDD max eMMC CSD VDD_W_CURR_MIN = 0x06 // Max. write current @ VDD min eMMC CSD VDD_W_CURR_MAX = 0x06 // Max. write current @ VDD max eMMC CSD C_SIZE_MULT = 0x01 // Device size multipli er eMMC CSD ERASE_GRP_SIZE = 0x1F // Erase group size eMMC CSD ERASE_GRP_MULT = 0x1F // Erase group size mul tiplier eMMC CSD WP_GRP_SIZE = 0x0F // Write protect group size eMMC CSD WP_GRP_ENABLE = 0x01 // Write protect group enable eMMC CSD DEFAULT_ECC = 0x00 // Manufacturer default ECC eMMC CSD R2W_FACTOR = 0x02 // Write speed factor eMMC CSD WRITE_BL_LEN = 0x09 // Max. write data bloc k length eMMC CSD WRITE_BL_PARTIAL = 0x00 // Partial blocks for w rite allowed eMMC CSD CONTENT_PROT_APP = 0x00 // Content protection a pplication eMMC CSD FILE_FORMAT_GRP = 0x00 // File format group eMMC CSD COPY = 0x01 // Copy flag (OTP) eMMC CSD PERM_WRITE_PROTECT = 0x00 // Permanent write prot ection eMMC CSD TMP_WRITE_PROTECT = 0x00 // Temporary write prot ection eMMC CSD FILE_FORMAT = 0x00 // File format eMMC CSD ECC = 0x00 // ECC code eMMC CSD CRC = 0x33 // CRC eMMC EXT_CSD S_CMD_SET = 0x00 // Supported Command Se ts eMMC EXT_CSD BOOT_INFO = 0x15 // Boot information eMMC EXT_CSD BOOT_SIZE_MULTI = 0x0A // Boot partition size eMMC EXT_CSD ACC_SIZE = 0x07 // Access size eMMC EXT_CSD HC_ERASE_GRP_SIZE = 0x00 // High-capacity erase unit size eMMC EXT_CSD ERASE_TIMEOUT_MULT = 0x04 // High-capacity erase timeout eMMC EXT_CSD REL_WR_SEC_C = 0x07 // Reliable write secto r count eMMC EXT_CSD HC_WP_GRP_SIZE = 0x01 // High-capacity write protect group size eMMC EXT_CSD S_C_VCC = 0x01 // Sleep current (VCC) eMMC EXT_CSD S_C_VCCQ = 0x01 // Sleep current (VCCQ) eMMC EXT_CSD S_A_TIMEOUT = 0x07 // Sleep/awake timeout eMMC EXT_CSD SEC_COUNT = 0x01D5A000 // Sector Count eMMC EXT_CSD MIN_PERF_W_8_52 = 0xA0 // Minimum Write Perfor mance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_52 = 0x00 // Minimum Read Perform ance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_W_8_26_4_52 = 0x00 // Minimum Write Perfor mance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_26_4_52 = 0x00 // Minimum Read Perform ance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_W_4_26 = 0x00 // Minimum Write Perfor mance for 4bit at 26MHz eMMC EXT_CSD MIN_PERF_R_4_26 = 0x00 // Minimum Read Perform ance for 4bit at 26MHz eMMC EXT_CSD PWR_CL_26_360 = 0x00 // Power class for 26MH z at 3.6V eMMC EXT_CSD PWR_CL_52_360 = 0x00 // Power class for 52MH z at 3.6V eMMC EXT_CSD PWR_CL_26_195 = 0x00 // Power class for 26MH z at 1.95V eMMC EXT_CSD PWR_CL_52_195 = 0x00 // Power class for 52MH z at 1.95V eMMC EXT_CSD CARD_TYPE = 0x01 // Card type eMMC EXT_CSD CSD_STRUCTURE = 0x00 // CSD structure versio n eMMC EXT_CSD EXT_CSD_REV = 0x00 // Extended CSD revisio n eMMC EXT_CSD CMD_SET = 0x02 // Command set eMMC EXT_CSD CMD_SET_REV = 0x05 // Command set revision eMMC EXT_CSD POWER_CLASS = 0x00 // Power class eMMC EXT_CSD HS_TIMING = 0x00 // High-speed interface timing eMMC EXT_CSD BUS_WIDTH = 0x00 // Bus width mode eMMC EXT_CSD ERASED_MEM_CONT = 0x00 // Erased memory conten t eMMC EXT_CSD BOOT_CONFIG = 0x00 // Boot configuration eMMC EXT_CSD BOOT_BUS_WIDTH = 0x00 // Boot bus width1 eMMC EXT_CSD ERASE_GROUP_DEF = 0x00 // High-density erase g roup definition EMMC eMMC DRIVER INIT COMPLETE » Downloading complete » Elapsed time: 0:01.860 (26200 bytes/s) » End loading driver » Downloading » Downloading 'Targets\Projects\espresso\MLO.hs' » Sending data (262144 bytes) :::::::::::::::::::: [262144] » Downloading complete » Elapsed time: 0:00.438 (598502 bytes/s) » Looking for a driver for 'EMMC' » chip_driver EMMC Targets\Flash-Drivers\emmc_drv.bin sid 1 width 4 delay 9 rpap i_base 0x00028400 » Downloading driver EMMC eMMC DRIVER DEINIT COMPLETE » Downloading 'Targets\Flash-Drivers\emmc_drv.bin' » Sending data (47160 bytes) :::::::::::::::::::: [47160] Interface 'OMAPFLASH DRIVER v6' Driver 'eMMC JESD84-A43' Driver configuration: sid = 0x00000001 Driver configuration: width = 0x00000004 Driver configuration: delay = 0x00000009 Driver configuration: rpapi_base = 0x00028400 MMC sid = 0x01 MMC mmc_volt = 0x01 MMC data_width = 0x04 MMC card_rca = 0x04 MMC card_type = 0x03 MMC data_width_support = 0x08 MMC transfer_clk_max = 0xBB80 MMC card_size = 0x1D5A000 eMMC CID MID = 0x15 // Manufacturer ID eMMC CID CBX = 0x01 // Card/BGA eMMC CID OID = 0x00 // OEM/Application ID eMMC CID PNM = 0xA99B00001F49 // Product name eMMC CID PRV = 0x19 // Product revision eMMC CID PSN = 0x00001F49 // Product serial numbe r eMMC CID MDT = 0x1F // Manufacturing date eMMC CID CRC = 0x24 // CRC7 checksum eMMC CSD CSD_STRUCTURE = 0x03 // CSD structure eMMC CSD SPEC_VERS = 0x04 // System specification version eMMC CSD TAAC = 0x27 // Data read access-tim e 1 eMMC CSD NSAC = 0x01 // Data read access-tim e 2 in CLK cycles (NSAC*100) eMMC CSD TRAN_SPEED = 0x32 // Max. bus clock frequ ency eMMC CSD CCC = 0x00F5 // Card command classes eMMC CSD READ_BL_LEN = 0x09 // Max. read data block length eMMC CSD READ_BL_PARTIAL = 0x00 // Partial blocks for r ead allowed eMMC CSD WRITE_BLK_MISALIGN = 0x00 // Write block misalign ment eMMC CSD READ_BLK_MISALIGN = 0x00 // Read block misalignm ent eMMC CSD DSR_IMP = 0x00 // DSR implemented eMMC CSD C_SIZE = 0x00FF // Device size eMMC CSD VDD_R_CURR_MIN = 0x06 // Max. read current @ VDD min eMMC CSD VDD_R_CURR_MAX = 0x06 // Max. read current @ VDD max eMMC CSD VDD_W_CURR_MIN = 0x06 // Max. write current @ VDD min eMMC CSD VDD_W_CURR_MAX = 0x06 // Max. write current @ VDD max eMMC CSD C_SIZE_MULT = 0x01 // Device size multipli er eMMC CSD ERASE_GRP_SIZE = 0x1F // Erase group size eMMC CSD ERASE_GRP_MULT = 0x1F // Erase group size mul tiplier eMMC CSD WP_GRP_SIZE = 0x0F // Write protect group size eMMC CSD WP_GRP_ENABLE = 0x01 // Write protect group enable eMMC CSD DEFAULT_ECC = 0x00 // Manufacturer default ECC eMMC CSD R2W_FACTOR = 0x02 // Write speed factor eMMC CSD WRITE_BL_LEN = 0x09 // Max. write data bloc k length eMMC CSD WRITE_BL_PARTIAL = 0x00 // Partial blocks for w rite allowed eMMC CSD CONTENT_PROT_APP = 0x00 // Content protection a pplication eMMC CSD FILE_FORMAT_GRP = 0x00 // File format group eMMC CSD COPY = 0x01 // Copy flag (OTP) eMMC CSD PERM_WRITE_PROTECT = 0x00 // Permanent write prot ection eMMC CSD TMP_WRITE_PROTECT = 0x00 // Temporary write prot ection eMMC CSD FILE_FORMAT = 0x00 // File format eMMC CSD ECC = 0x00 // ECC code eMMC CSD CRC = 0x33 // CRC eMMC EXT_CSD S_CMD_SET = 0x00 // Supported Command Se ts eMMC EXT_CSD BOOT_INFO = 0x15 // Boot information eMMC EXT_CSD BOOT_SIZE_MULTI = 0x0A // Boot partition size eMMC EXT_CSD ACC_SIZE = 0x07 // Access size eMMC EXT_CSD HC_ERASE_GRP_SIZE = 0x00 // High-capacity erase unit size eMMC EXT_CSD ERASE_TIMEOUT_MULT = 0x04 // High-capacity erase timeout eMMC EXT_CSD REL_WR_SEC_C = 0x07 // Reliable write secto r count eMMC EXT_CSD HC_WP_GRP_SIZE = 0x01 // High-capacity write protect group size eMMC EXT_CSD S_C_VCC = 0x01 // Sleep current (VCC) eMMC EXT_CSD S_C_VCCQ = 0x01 // Sleep current (VCCQ) eMMC EXT_CSD S_A_TIMEOUT = 0x07 // Sleep/awake timeout eMMC EXT_CSD SEC_COUNT = 0x01D5A000 // Sector Count eMMC EXT_CSD MIN_PERF_W_8_52 = 0xA0 // Minimum Write Perfor mance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_52 = 0x00 // Minimum Read Perform ance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_W_8_26_4_52 = 0x00 // Minimum Write Perfor mance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_26_4_52 = 0x00 // Minimum Read Perform ance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_W_4_26 = 0x00 // Minimum Write Perfor mance for 4bit at 26MHz eMMC EXT_CSD MIN_PERF_R_4_26 = 0x00 // Minimum Read Perform ance for 4bit at 26MHz eMMC EXT_CSD PWR_CL_26_360 = 0x00 // Power class for 26MH z at 3.6V eMMC EXT_CSD PWR_CL_52_360 = 0x00 // Power class for 52MH z at 3.6V eMMC EXT_CSD PWR_CL_26_195 = 0x00 // Power class for 26MH z at 1.95V eMMC EXT_CSD PWR_CL_52_195 = 0x00 // Power class for 52MH z at 1.95V eMMC EXT_CSD CARD_TYPE = 0x01 // Card type eMMC EXT_CSD CSD_STRUCTURE = 0x00 // CSD structure versio n eMMC EXT_CSD EXT_CSD_REV = 0x00 // Extended CSD revisio n eMMC EXT_CSD CMD_SET = 0x02 // Command set eMMC EXT_CSD CMD_SET_REV = 0x05 // Command set revision eMMC EXT_CSD POWER_CLASS = 0x00 // Power class eMMC EXT_CSD HS_TIMING = 0x00 // High-speed interface timing eMMC EXT_CSD BUS_WIDTH = 0x00 // Bus width mode eMMC EXT_CSD ERASED_MEM_CONT = 0x00 // Erased memory conten t eMMC EXT_CSD BOOT_CONFIG = 0x00 // Boot configuration eMMC EXT_CSD BOOT_BUS_WIDTH = 0x00 // Boot bus width1 eMMC EXT_CSD ERASE_GROUP_DEF = 0x00 // High-density erase g roup definition EMMC eMMC DRIVER INIT COMPLETE » Downloading complete » Elapsed time: 0:01.844 (26200 bytes/s) » End loading driver » Downloading » Downloading 'Targets\Projects\espresso\Sbl.bin' » Sending data (1310720 bytes) :::::::::::::::::::: [1310720] » Downloading complete » Elapsed time: 0:01.984 (689850 bytes/s) » cold_sw_reset » Elapsed time: 0:13.031 Devam etmek için bir tuşa basın . . . C:\Documents and Settings\Administrator\Desktop\yeniflash\OMAPFlash_1229_2ndlast t>GOTO __loop » OMAPFlash v4.15 (Aug 12 2011) » -v » Entering parameter file:Targets\Projects\espresso\omap4430hs_1200MHZ.txt at li ne: 1 » -omap 4 » -t 36000 » -p OMAP4430_8G_HS » -2 » chip_download EMMC Targets\Projects\espresso\MLO.hs » chip_download EMMC Targets\Projects\espresso\Sbl.bin » command cold_sw_reset » Leaving parameter file:Targets\Projects\espresso\omap4430hs_1200MHZ.txt » @Targets\Projects\espresso\omap4430hs_1200MHZ.txt » Looking for device (omap usb) » Please turn on device » Waiting for device (omap usb) | |
Nokia "Contact Service" Repairer | Dirk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-04-2011 05:45 |
New!! Nokia Flash Checksum And Contact Service Repair | HookerGsM | Main Sales Section | 0 | 01-02-2001 10:12 |
Unlock all locks all phones *HERE* | manfred | GSM Mobile Links | 0 | 02-19-2000 10:50 |
buy your GSM here | midlandcellular | Main Sales Section | 0 | 09-04-1999 17:14 |
