Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-02-2017, 08:33 | #1 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1873771 Status: Offline Sonork: GSM-forum Thanks Meter: 0 | SAMSUNG j200g system rev check fail device:1 binary:0 samsung j200g system rev check fail device:1 binary:0 and odin mode frp ; lock..... |
02-02-2017, 10:09 | #4 (permalink) |
Member: 1873771 Status: Offline Sonork: GSM-forum Thanks Meter: 0 | Searching Samsung USB Flash interface... COM212 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... error |
02-02-2017, 12:56 | #6 (permalink) | |
Freak Poster Join Date: Sep 2016 Location: Pakistan
Member: 2631161 Status: Offline Thanks Meter: 760 | Quote:
Dev-Host - J200GUDXU1AOK1_OLB1AOK1_v5.1.1_Repair_Firmware.zip - The Ultimate Free File Hosting / File Sharing Service | |
02-02-2017, 13:40 | #7 (permalink) |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Hello, * SmartSwitch Error * Binary Error J200G PL7 Sboot Just Write This File Using BL Your Handset Alive Normal !! Then Use Supported Tool For Reset FRP Good Luck ... Regards, ________ |
02-04-2017, 11:12 | #14 (permalink) |
Member: 1873771 Status: Offline Sonork: GSM-forum Thanks Meter: 0 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J200G Software version: 27.7 File analysis... Ok Total file size: 0x8D957000 (2265 Mb) Searching USB Flash interface... COM226 detected Setup connection... Ok Reading PIT from phone... Ok Sending sboot.bin... Ok Sending boot.img... error timeout It looks like you have an unsucessful operation, try this link for solution - Last edited by gsm mithun roy; 02-23-2017 at 08:52. |
