Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 10-09-2015, 20:38   #1 (permalink)
freeman2001's Avatar
Member: 206476
Thanks Meter: 459
i9195 Stuck On Samsung Solution
Hello Bros
This Phone stuck on samsung With bleu recovery in top of lcd
Reflash it by all Fw even His original get it from his SN number all the times same
I erase his EMMc by easy JTAG reflash it again is same
I change his emmc And flash it with many fw and all the time is same
also with costum recovery .... all the time same caso hang on logo
so any solution for this ?
zbr
Old 10-15-2015, 09:26   #2 (permalink)
Member: 144223
Thanks Meter: 10
did u make efs after flash with full firmware?
Old 10-16-2015, 05:27   #3 (permalink)
..::CHAIN::..'s Avatar
Member: 1753928
Sonork: 100.1615906
Thanks Meter: 2,318
Hello,
Once More Try With Flashing Efs.Tar Before Write Default Efs.... Its Work Well For Me Many Times. Good Luck....
Regards,
Old 10-17-2015, 18:23   #4 (permalink)
Member: 206476
Thanks Meter: 459
i do it as i said i change even new emmc but same problem
Old 10-17-2015, 19:03   #5 (permalink)
Member: 144223
Thanks Meter: 10
Do u write correct boot receovery?
I found many emmc (sandisk) with problem but not seems this case.
I always write boot recovery and after with mmc inside i write efs (odin 3.04) and after i write full firmware.
i think the problem is on the line of display or can be cpu gone.
Page generated in 0.12412 seconds with 8 queries
