Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2007
Member: 534777 Status: Offline Thanks Meter: 214 | i9300 S3 screen upside down when you power the phone on normally,the screen is full of rainbow coloured dots. i tested the screen with a working board and all worked ok. what could the problem be and how do i go about fixing this??? thanx and best wishes |
![]() | #4 (permalink) |
Junior Member ![]() Join Date: Nov 2013
Member: 2057739 Status: Offline Thanks Meter: 4 | wodashie its not problem of emmc if ur all screen is white wid red and black lines dont worry download mg4 firmware (I9300XXEMG4) and mx.pit file and flash with odin ur screen problem is solved after dat next step u have to repair efs with octopus box nd root ur mobile and repair imei nd ur ph is ready i fix 10 mobiles same problem and one thing after repair efs if ur basband is null u have to change emmc chip best of luck ....and post result here ![]() |
![]() | #5 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2012 Location: Beirut Age: 37
Member: 1759307 Status: Offline Sonork: 100.1636995 Thanks Meter: 56 | it is normal to get downloading image upside down after dead boot repair, that means u r in the right track, now all u have to do is to flash the phone with 4 file firmware with pit and repartition selected |
![]() | #6 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2000 Location: North / East Uk .... Pussy Hunter . Age: 35
Member: 2461 Status: Offline Thanks Meter: 22 | Quote:
Have also got the same fault with an i9300 Can this be done with Z3x ? I am trying with odin v3.07 but the clear efs button is greyed out ![]() maybe as my flash is only 1 file , just trying to find the 4 file flash | |
![]() | #7 (permalink) |
Member: 2057739 Status: Offline Thanks Meter: 4 | if ur phone with white screen with lines u have flash with 4 files flash(mg4) with pit file nd for repair efs i never try z3x bz i have octopus box i fix with octopus box. i read posts on this fourm for repair imei with efs select model in z3x i9100 and tick repair efs and write new imei . i dont knw which z3x software version is working for that u have too check it . bz when i try to unlocking or repair imei i have to change every time samsung software version thats why i use octopus box..try ur luck man ... |
![]() | #8 (permalink) | |
Member: 534777 Status: Offline Thanks Meter: 214 | Quote:
best wishes | |
The Following User Says Thank You to wodashie For This Useful Post: |
![]() | #10 (permalink) | |
NEED FULL FLASH FOR I9300 FOR NOW TO FIX IT. SADLY THE FEW I FOUND ARE HOSTED ON ''HOTFILE DOT COM'' WHICH HAS BEEN SHUT DOWN SO WILL APPRECIATE SOMEONE MAKING IT AVAILABLE FOR ME. THANX AND BEST WISHES | |
![]() | #11 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2007
Member: 550428 Status: Offline Thanks Meter: 25 | i got i9300 came with cant on even download mode also not respon, i was use a memory card to make it alive then download mode screen was upside down. i flash it with odin pit + pda modem csc, the phone alive back but imei was null/null, product name blank and baseband unknown. how to fix imei null/null and product name blank? |
![]() | #12 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2012
Member: 1740134 Status: Offline Thanks Meter: 52 | Quote:
after that, you will get imei 0049......... . root your phone and repair imei with z3x or any other box. | |
