Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
04-02-2013, 13:36 | #1 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1423624 Status: Offline Thanks Meter: 7 | i9000 flash fail hello after flash i9000 not done odin3 [IMG]http://im39.******.com/9K3vk.png[/IMG] withou z3x same probleme [IMG]http://im38.******.com/XpX06.png[/IMG] pleaaase |
04-02-2013, 13:43 | #2 (permalink) |
Member: 1423624 Status: Offline Thanks Meter: 7 | flash fail with odin 3 <ID:0/158> Added!! <ID:0/158> Odin v.3 engine (ID:158).. <ID:0/158> File analysis.. <ID:0/158> SetupConnection.. <ID:0/158> Initialzation.. <ID:0/158> Get PIT for mapping.. <ID:0/158> Firmware update start.. <ID:0/158> boot.bin <ID:0/158> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) with z3x Selected model: I9000 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x1772D5FC Searching USB Flash Interface... detected COM158 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\I9000_2-4-2013_12-43-9.pit Sending boot.bin... Error Done with Samsung Tool v.14.2 |
04-04-2013, 15:51 | #3 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1853353 Status: Offline Thanks Meter: 0 | Hello! I new z3x user pls help me! I wanna unlock me i9000 but i cant becouse this wrote me the box:searching usb flash interface... not found pls help me. what need me install?, I've installed everything. I use XP And i try 2g 14.2 and 3g 9.4 |
04-04-2013, 16:44 | #4 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
Z3X-Team Products - GSM-Forum anyway I think you will need to root the phone before being able to make the unlock. double check as well if you activated the usb debugging and you gave the codes asked in the help frame about this model BR Alex | |
The Following User Says Thank You to moulnisky For This Useful Post: |
