How can i fix it permament |
After root, i freezed/ stopped securityLog agent as it was giving unauthorized action message. Now i noticed my fingerprint sensor not working. Maybe due to all root and security agent freeze thing. So can i permanent fix mipi to work on stock? Or how to make fingerprint sensor work again |
Dear all what i did is fixed mipi rebuild nvrm , reboot. network comes. then i flashed to stock rom without any wide / factory reset. now i am on my stock rom , with fingerprint working , mipi ok , network working. But i am not sure , what will happen if i preform factory reset now. after reset , if mipi fails , i have to root it again , have to fix mipi again and then have to load stock. anyone has idea if mipi is fixed permanent or not? but i am on my stock rom now |
I just performed factory reset, and mipi was ok. Phone got network and worked fine. Then phone recieved OTA update and i clicked to update. Mipi failed after update again. I think it's software issue. Because when phone restarts to update, several green lines, some written codes come, then phone restarts and update was successful. Mipi failed immideatly after phone turned on after update. I recieved one text message, and then suddenly network disappeared. |
My phone surely have sw problem. My phone is G930T. It all started when i flashed G930U firmware in it and inserted sim card.my phone told me to update configuration and it restarted showing Blue samusng screen. Something happened for 1 minute, phone restart and network disappeared.. Then i flashed back to G930T But after that mipi remains fail. |
This is gr8 share and you got only 16 THANKS ?????? :eek: This post deserve to have at last 100 Thanks Bro, you should not share or get tired to help members that are lazy to press thanks button for such a gr8 post. Most of members stop sharing because of non-thankfully members. |
we will add v2.0 New Update soon br, ahmedzitoon |
waiting for new update bro |
Repair Mipi Tool By World1st Group Developers Nurul Amin | AhmedZitoon https://www.facebook.com/Zitooon Phone must be rooted Search Adb device.... >> Device Found! Reading Info............ MANUFACTURER : SAMSUNG HARDWARE : QCOM MODEL : SM-G9350 BASEBAND : MSM BOARD : MSM8996 VERSION : 8.0.0 DEVICE TYPE : COUNTRY CODE : CONNECTION MODE : MTP,ADB Search Adb device.... >> Device Found! Reading Info............ MANUFACTURER : SAMSUNG HARDWARE : QCOM MODEL : SM-G9350 BASEBAND : MSM BOARD : MSM8996 VERSION : 8.0.0 DEVICE TYPE : COUNTRY CODE : CONNECTION MODE : MTP,ADB Repair Mipi Success!! =========================== Hints : Popup Will Show , Go Setting , System , And Go To Rebuild Nvrm Then Reboot Can t open hedden menu how to do plz |
this works for like a cert patch? |
What model list supported? |
pleas upload ;) |
G532F no popup showing what to do.? |
