Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
12-01-2013, 19:02 | #1 (permalink) |
Major Poster Join Date: Oct 2013
Member: 2044745 Status: Offline Thanks Meter: 20 | N7100 emergency calls only after update 4.3 solution I flashed my phone to 4.3 indian firmware and lost signal. the indian 4.3 locks the bootloader to knox making it impossible to downgrade for now but you can patch the modem to make it work. what u need download Philstouch recovery from this link and flash via odin in pda. Dev-Host - philz_touch_5.15.0-n7100.zip - The Ultimate Free File Hosting / File Sharing Service Download the Patched_N7100_MK4_KERNEL from this link https://doc-14-9s-docs.googleusercon...l10arhrl26c0ip also download the patched modem from this link https://dl.dropboxusercontent.com/s/...9.zip?dl=1&tok copy these two files to phone on sd card memory and boot into recovery (the phil's touch recovery you flashed.) select install zip from sdcard and choose the kernel first and flash select again install from sdcard and flash the modem then reboot. you should have full network. thanks to zuluman from xda. |
The Following 10 Users Say Thank You to :gsmcoder: For This Useful Post: |
12-03-2013, 13:51 | #2 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: INSIDE OUT
Member: 1015414 Status: Offline Thanks Meter: 155 | Quote:
link no 2 | |
12-03-2013, 18:32 | #3 (permalink) |
Member: 2044745 Status: Offline Thanks Meter: 20 | |
The Following User Says Thank You to :gsmcoder: For This Useful Post: |
12-05-2013, 12:02 | #10 (permalink) |
Member: 1015414 Status: Offline Thanks Meter: 155 | ok ill w8... or just send in my yahoo..plss need [email protected] |
