Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-23-2017, 12:04 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: ..:Inside UR Brain:.. Age: 34
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | SM-G935F Nougat 7.0 Successfully Root [Available] first flash this twrp recovery TWRP Recovery install this SuperUser |
The Following 7 Users Say Thank You to shaikh_shoeb50 For This Useful Post: |
03-23-2017, 16:45 | #2 (permalink) | |
Freak Poster Join Date: Nov 2015 Location: karachi
Member: 2486328 Status: Offline Sonork: 100.1660495 Thanks Meter: 79 | Quote:
i try this twrp bootloop & always flash failed odin & z3x both failed <ID:0/008> Added!! <ID:0/008> Odin engine v(ID:3.1205).. <ID:0/008> File analysis.. <ID:0/008> SetupConnection.. <ID:0/008> Initialzation.. <ID:0/008> FAIL! (DeviceInfo) <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/008> Removed!! FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G935FD Software version: 27.8 File analysis... Ok | |
The Following 2 Users Say Thank You to Furqanwali For This Useful Post: |
03-23-2017, 22:24 | #3 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | CF-Auto-Root is now available from the repo -CF-Auto-Root-hero2lte-hero2ltexx-smg935f.zip Download SM-G935FD 6.0.1 ROOT or S7 Edge 6.0.1_TWRP_Root_100%_Tested.zip RAR PASS:- gsmhosting Before flashing, make sure you have enabled "OEM unlock" from "Developer Settings" ! Note that CFAR's display code isn't yet compatible with the S7, as such, there is no output on screen. This means that after flashing with ODIN, the device will only show you the S7 logo, and it seems like nothing happens. Just leave the device alone for 5 minutes. It'll reboot a few times, then boot into Android, but now you have root. If it still doesn't do anything after 5 minutes, something has gone wrong, and you should probably reflash your stock boot.img and recovery.img. ==> Source XDA
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 10-25-2017 at 09:55. Reason: Information has been update |
The Following 2 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
05-13-2017, 05:39 | #5 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Pakistan Age: 24
Member: 2488001 Status: Offline Sonork: 100.1669288 Thanks Meter: 295 | Samsung Galaxy S7 SM-G930F 7.0 Nougat TwrpRecovery & Root. Samsung Galaxy S7 SM-G930F 7.0 Nougat Twrp Recovery & Root. 1) Connect phone in download mode using vol down + home + power. 2) Connect phone to pc and open odin. 3) Select TWRP in ap in odin and start (auto reboot tic must be unchecked). 4) Power of phone and boot in recovery Vol up + home + power. 5) Select Advance then select adb sideload and do slide to start. 6) Now run runme.batch from supersu files you downloaded. twrp link twrp-3.0.2-4-herolte-apollo.img kernal link exynos8890-apollo-v1.8.0 super SU https://download.chainfire.eu/1021/S...etrieve_file=1 |
The Following 6 Users Say Thank You to Salman725626 For This Useful Post: |
08-24-2018, 12:54 | #7 (permalink) |
Junior Member Join Date: Aug 2018 Location: delhi
Member: 2859417 Status: Offline Sonork: [email protected] Thanks Meter: 3 | problem solved after twrp wipe format phone alive now THX BRO |
08-29-2018, 12:12 | #8 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Alipur
Member: 2683134 Status: Offline Thanks Meter: 59 | Samsung S7 Edge G935P Root 7.0 Kernel U5 U5 Binary on S7 Edge G935P, G935A, G935T, G935V, G935T1 frp method https://www.howunlock.com/samsung-s7...tested-method/ |
