Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 03-08-2017, 01:40   #1 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,166
[ROOT] SM-G928P (Sprint) Galaxy S6 Edge Plus
Root SM-G928P 6.0.1
Download root file for G928PVPU2BPH9.
Extract CF-Root zip file that you downloaded earlier from above link, you will get a .tar.md5, Odin3-v3.07.exe and few other files within extracted folder.
Power off your Android device. Wait 5-6 seconds for vibration to confirm complete switch off.
Now, put the Galaxy S6 Edge Plus SM-G928P (Sprint) in Download Mode by pressing and holding down the Volume Down, Home and Power button together.
A warning screen will come up; press Volume Up button to enter Download Mode.
Now run Odin3 v3.07.exe (see Step 3) as an Administrator because Admin privileges is required to complete the process smoothly (only applicable Windows Vista and higher).
Now connect your device to your PC using USB cable. An “Added!!” massage will appear in Odin’s message box. If you don’t get the same then you should try another USB port (try USB port located in back in your desktop PC).
If that too don’t work then you should reinstall the driver. If you successfully see the “Added!!” message in Odin then you are ready to go in next step.
You should also see COM port with a number in Yellow if you successfully added your device.
Click the PDA Button, and select that CF-Auto-Root-zenltespr-zenltespr-smg928p.tar.md5 file that you get in Odin window, make sure only Auto Reboot and F. Reset Time checkboxes are selected.
Double check everything that we mentioned in above. Now, once satisfied hit the START button to begin the flashing process.
Once flashing completed, your Galaxy S6 Edge Plus SM-G928P (Sprint) will restart and soon you will see a PASS message with green background in the left-most box at the very top of the Odin.
You can now unplug the USB cable to disconnect your device from computer.
Credit goes to ==> CF-Root & XDA
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
The Following 4 Users Say Thank You to ...:::::NP™:::::... For This Useful Post:
Page generated in 0.12581 seconds with 8 queries
