Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
![]() | #1 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Dec 2001 Location: USA
Member: 7805 Status: Offline Thanks Meter: 186 | [Root] step by step Manual i9082 (L) Galaxy GRAND STEP BY STEP rooting manual for GSM-Hosting users Just follow this simple steps: 1. Step - Download Samsung USB drivers ----> Click HERE - Download ODIN 3.04 from ----> Click HERE - Download i8092 recovery image prerooted ----> Click HERE - Download SuperSu Last version ----> Click HERE 2. Step - Turn off phone, then switch to download mode: press together [volume down]+[home button]+[power button] (all at once), press [volume up] for comfirm download mode. - Connect usb cable, install drivers. 3. Step - Run Odin 3.04, ticked 2 option F.reset times+auto reboot, - Extract CWM-touch_i9082_chotu.tar.zip !Select PDA and browse to where you have extracted CWM-touch_i9082_chotu.tar.md5 and select it 4. Step - Odin should show device under 1 of ID:COM port.(if this not happends repeat from STEP 2) - Press START. - Phone should power on after flashing complete. 5. Step - ROOTING: - Copy Downloaded SUperSU to externel sdcard (NOT INTERNAL ! ) - Power off your phone, after press [Vol up] + [Power] + [Home button] (all at once) - SelectInstall zip from sdcard --->choose zip from sdcard ---> scroll down and select Fix Recovery.zip and again choose zip from sdcard and flash UPDATE-SuperSU-v1.05.zip Done ! And you are ready to go ![]() thanks goes to chotu. |
The Following 35 Users Say Thank You to drozd For This Useful Post: |
![]() | #4 (permalink) |
Member: 7805 Status: Offline Thanks Meter: 186 | 100% work. i have post only tested personaly by me root solution. I have now i9082 , post here your problem. may be you did something wrong ![]() |
![]() | #5 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2008 Location: Anwar Telecom .DHAKA Age: 39
Member: 896667 Status: Offline Sonork: 100.1586139 Thanks Meter: 1,596 | I TRY BUT E:failed to verify whole-file signature ![]() |
The Following User Says Thank You to dvd_anwar For This Useful Post: |
![]() | #12 (permalink) |
Junior Member ![]() ![]() Join Date: Jul 2004 Location: Jakarta
Member: 71574 Status: Offline Thanks Meter: 0 | After flashing cwm via odin, should pull off the battery first and then turn on the handheld in cwm mode. after that try to flash the update-supersu.zip again Hope it helps Sent from my iPad using Tapatalk HD |
![]() | #15 (permalink) |
Super Moderator ![]() Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 2,041 | Solution Is Very Easy Only Used This Recovery Dev-Host - recovery_k2wl.v1.tar - The Ultimate Free File Hosting / File Sharing Service |
