Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
10-17-2017, 16:22 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | N950f Frp solution Please if any working solution post it here |
10-17-2017, 19:30 | #2 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | COMBINATION_FA70_N950FXXU1AQH7_CL12128666_QB146908 69_REV00_user_mid_noship.tar.rar not my upload, credit goes to uploader... no password |
The Following User Says Thank You to voltran2008 For This Useful Post: |
10-17-2017, 19:42 | #3 (permalink) |
Member: 861795 Status: Offline Thanks Meter: 1,275 | After flashing with combination you must flash official firmware with all files.. Select HOME_CSC_XXX... instead of CSC_XXX... do not use pit file... Flashing with HOME_CSC_XXX will do an update without an erase so ADB will be kept enabled... |
12-08-2017, 21:45 | #8 (permalink) |
No Life Poster Join Date: Jan 2011 Location: Cuba
Member: 1484663 Status: Offline Thanks Meter: 344 | Hi, the ONLY way I could remove the FRP was like this: 1-Flash combination 2-Flash from 4 files firmware from AP part ONLY "system" You can do it with Z3X, Octopus or just decompress AP part with 7zip and convert system into .tar 3-Very quickly from lockscreen swipe down goto settings and activate "OEM unlock" on developer options. It took me like 20 attemps. The device reboots very fast into panick kernel. Just press Vol- and Power to reboot into normal mode again 4-Once OEM unlock it's ON flash with full firmware. Enjoy! This is the working way I just finished one N950F right now. If it help you just hit "Thanks" |
The Following 10 Users Say Thank You to Bscaine For This Useful Post: |
12-15-2017, 13:19 | #10 (permalink) |
Junior Member Join Date: Jan 2016 Location: missouri, USA
Member: 2515120 Status: Offline Thanks Meter: 9 | Alternative FRP / Reactivation lock method(s) adb enable firmware adb shell am start -n com .android .settings / com .android. settings. Settings (remove spaces.....should launch settings menu putting you behind setup wizard) adb shell su dd if=/dev/zero of=/dev/block/sda11 dd if=/dev/zero of=/dev/block/sda13 (above code used for removing rent-a-center locks) or adb shell su dd if=/dev/zero of=/dev/block/bootdevice/by-name/persist dd if=/dev/zero of=/dev/block/PERSISTENCE |
12-24-2017, 10:37 | #11 (permalink) | |
Insane Poster Join Date: Jan 2015
Member: 2332515 Status: Offline Sonork: 100.1678906 Thanks Meter: 88 | Quote:
hi dear, follow this link your problem will be solved. http://forum.gsmhosting.com/vbb/f684...l#post12817165 | |
12-24-2017, 10:38 | #12 (permalink) | |
01-19-2018, 01:10 | #13 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: egypt
Member: 194207 Status: Offline Sonork: 100.1602647 Thanks Meter: 167 | Quote:
its working man just do it quickly thanks so much thanks mony_valley | |
The Following User Says Thank You to mony_valley For This Useful Post: |
01-23-2018, 17:48 | #14 (permalink) | |
Freak Poster Join Date: Jul 2014 Location: 149.3.27.22 Age: 38
Member: 2229851 Status: Offline Thanks Meter: 55 | Quote:
The Following 2 Users Say Thank You to STAR* For This Useful Post: |
02-01-2018, 18:34 | #15 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: France 72,77
Member: 521955 Status: Offline Thanks Meter: 261 | Quote:
I try many time but i see only 'installing applications", not possible to go to menu. I see 1 second the menu but after, black screen with installing application and reboot to kernel panic. I try in safe mode or not, same. It's normal or other solution please. Thank's for all | |
The Following User Says Thank You to orangade For This Useful Post: |
