This frp file helps you to remove frp from your Samsung Galaxy A22 5G (SM-A226B) Android phone. The Samsung. Download the Samsung SM-A226B FRP reset File and use it to remove the FRP lock from your smartphone. You will be able to unlock the FRP.
How to Use?
- Now go to Device Manager and look at the Com Port on your phone
- Run SP Flash Tool to FRP Bypass Lock on Samsung A22 5G (A226b)
- Select the FRP and DA file
- Now go to the Format Tab and choose Manual Format Flash from the drop-down menu.
- Copy and paste the 0x1E000000 code into the Begin Address[HEX] field.
- Copy and paste the 0x80000 code into the Format Length[HEX] field.
- To begin, press the Start button.
- Wait till everything is finished.
Download:
Click Here
