Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 02-22-2023, 22:57   #1 (permalink)
Member: 2968275
Samsung A326B (A32 5G) Bootloop - recovery doesnt work
Hey guys, I require some assistance.
I have a Samsung A32 5G here that is in a constant boot-loop (can't even turn it off).
The user said it (supposedly) shut off during an update and it's been turning on and off ever since.
I've downloaded like 3 different (i'm sure they are proper)firmware versions and none of them want to install through odin.
I've also downloaded a few different .pit files and used the ones within the firmware files - they also do not work.
Nand erase, reformat - nothing.
Recovery is unusable - it displays an error message for 1 second then restarts.
Only thing that is semi-working is download mode (at least it stays on).
what to do, any ideas? I didn't even know a failed update can cause this much problems/damage.
Old 01-09-2025, 08:22   #2 (permalink)
Member: 10814
Hey. I have the same problem on the same model. I/O Error means a memory access error. If anyone has a solution, please let me know.
Old 01-10-2025, 19:54   #3 (permalink)
Member: 2968275
As I recall someone told me that the phone's NAND memory is corrupted and repair would be unfeasable cost-wise (since it's a lower end phone), unless you want to recover your data.
Page generated in 0.11809 seconds with 9 queries
