Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
09-11-2015, 07:34 | #1 (permalink) |
Banned Join Date: Nov 2012 Location: unknown
Member: 1837438 Status: Offline Sonork: unknown Thanks Meter: 659 | Samsung Factory Reset Protection(FRP) Samsung Factory Reset Protection(FRP) What Is Factory Reset Protection(FRP)? Android Factory Reset Protection (FRP) is a new feature to protect your device which has been added to several Samsung devices that are running Android OS 5.1 or higher. This feature allows you to set up your device to prevent other people from using it if it's been reset to factory settings without your permission. For example, if your device is lost, stolen, flashed, or wiped, only someone with your Google account or screen lock information can perform a factory data reset and use the device. When a device is factory reset, the device will not be able to be setup without the user entering the Google Account associated with the device (for hard reset) or screen lock information (for reset in Settings menu). How To Protect Your Device? If you reset your device to factory settings with the Factory Reset Protection (FRP) feature turned on, you must enter the user name and password for the last registered Google Account to regain access to the device. You will not be able to access the device without the correct credentials. This Google account verification prevents unauthorized users from accessing or using your device if it has been reset to factory settings without your permission (for example, if your device is lost or stolen). You should remove your Google account before shipping your device to Samsung or any other service provider for service and before resetting the device to factory settings. How Do I Setup? 1)In Galaxy SŪ 5 Sport *Tap the Settings icon. *Scroll to the System section and tap Security. *To enable Reactivation lock, scroll to and tap to check Reactivation lock. *Review the Reactivation lock prompt and tap OK. *Enter the Samsung Account password then tap CONFIRM. *The Reactivation lock feature has been enabled. 2)In Samsung Galaxy S6 *From the Home screen, touch Apps *Touch Settings. *Touch the PERSONAL tab. *Touch Lock screen and security. *Touch Find My Mobile. *Touch the slider OFF to turn Reactivation lock ON. *Review the information and touch OK. *When resetting your device, you will be prompted to confirm your Samsung account password. *Your device will reboot and reset. How To Disable Reactivation Lock. *Tap to uncheck Reactivation lock. *Review the Turn off Reactivation lock prompt and tap OK. *Enter the Samsung Account password, then tap CONFIRM. *The Reactivation lock feature has been disabled. Source:Samsung.com USE ONLY BUTTON IN DOWN RIGHT CORNER Br, Habeeb Kambrath Last edited by habeebkambrath; 09-11-2015 at 07:49. |
The Following 62 Users Say Thank You to habeebkambrath For This Useful Post: |
09-11-2015, 08:17 | #2 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2056879 Status: Offline Sonork: n/a Thanks Meter: 0 | Very good feature i have always dreamt of this security status. My worry would b if i forget that password..... What would i end up with..... Sent from my GT-I9300 using Tapatalk |
09-12-2015, 01:54 | #3 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1085379 Status: Offline Thanks Meter: 65 | Fap lock and reactivation lock two different lock types here you show how to activate reactivation lock not fap lock Sent from my ONE A2001 using Tapatalk |
The Following User Says Thank You to coolmfarshard For This Useful Post: |
09-12-2015, 07:59 | #4 (permalink) |
Member: 1837438 Status: Offline Sonork: unknown Thanks Meter: 659 | You Can Also Set The Lock The Initial Setup & First Use Time... br, Habeeb Kambrath |
The Following 2 Users Say Thank You to habeebkambrath For This Useful Post: |
09-15-2015, 05:17 | #6 (permalink) |
No Life Poster Join Date: Sep 2009
Member: 1128573 Status: Offline Thanks Meter: 242 | phone not stolen or loosing. accidentally user reset his phone. user forget his id and password. user must come to us for solve his problem. SO, HOW WE SOLVE THIS PROBLEM, BYPASS A/C ? thanks mahir |
09-15-2015, 10:52 | #7 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
bypass-any-samsung-google-verify-account-only-gsmideazone Speed 4Shared Download Link: http://forum.gsmhosting.com/vbb/11285157-post51.html No Thanks, Thank you itc... (OUT OF RULES FORUM) USE ONLY THISBUTTON IN DOWN RIGHT CORNER BR allumts | |
The Following 30 Users Say Thank You to allumts For This Useful Post: |
10-28-2015, 04:30 | #8 (permalink) |
Junior Member Join Date: May 2014
Member: 2184047 Status: Offline Thanks Meter: 1 | Follow the steps below: * Please backup your data before Factory Reset using Kies on your computer. App data is not backed up automatically. 1. From the Home screen touch Apps. 2. Touch Settings. 3. Touch the Accounts tab. 4. Touch Back up and reset 5. Touch Factory data reset 6. Touch Reset phone. 7. Touch Erase everything. |
11-13-2015, 11:59 | #10 (permalink) |
Banned Join Date: Oct 2002 Location: Feeding Carrots to useless,,
Member: 16490 Status: Offline Sonork: 100.1621293 Thanks Meter: 908 | @ Those mentioning Boxes / Dongles etc.. This is not a section to promote other teams products.. Br |
The Following 2 Users Say Thank You to bod For This Useful Post: |
11-15-2015, 11:10 | #11 (permalink) | |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | Quote:
The Following 4 Users Say Thank You to MGT SOFTWARE For This Useful Post: |
11-16-2015, 16:36 | #12 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Read carefully all Done S6 and S6 edge with this Free method: http://forum.gsmhosting.com/vbb/f777...l#post11413960 If read other Sticky thread can find more. |
The Following 4 Users Say Thank You to allumts For This Useful Post: |
11-26-2015, 12:17 | #13 (permalink) |
Junior Member Join Date: Nov 2015 Location: Hyderabad , India
Member: 2485182 Status: Offline Thanks Meter: 4 | Samsung Factory Reset Protection is the great features. Now I or anyone who are using Samsung smartphones, will not have worry about their mobiles have stolen or something. In case if It is stolen or loss, then you can track or when some one trying to open, then they will not able to do it with user Google Account associated. |
The Following User Says Thank You to pankaj554 For This Useful Post: |
11-26-2015, 15:58 | #14 (permalink) | |
Member: 1837438 Status: Offline Sonork: unknown Thanks Meter: 659 | Quote:
Now FRP Great Protection for Motorola...No any solution till now like Moto G... Send from my iPhone6 using Tapatalk | |
11-28-2015, 06:51 | #15 (permalink) |
Junior Member Join Date: Mar 2008 Location: London, United Kingdom
Member: 735806 Status: Offline Thanks Meter: 3 | I predict this will stop many people from stealing phones for drug money finally. Amazing how quickly your phone can disappear if you forgot about it for 2 minutes! |
