Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 11-01-2010, 03:16   #16 (permalink)
hoangtruongson's Avatar
Member: 392170
Sonork: 1587688
Thanks Meter: 150
Originally Posted by cyprus View Post
this device can be used to ?
Must repair by jtag phone is Debug mode
Old 11-01-2010, 10:59   #17 (permalink)
M_Alin's Avatar
Member: 187149
Sonork: 100.1611848
Thanks Meter: 33
I am also from Cyprus and i can help you to write the boot.
Old 11-04-2010, 22:17   #18 (permalink)
sonicpromo's Avatar
Member: 1177924
Thanks Meter: 56
Riff Box can repair dead boot of this phone. I managed to brick two of these phones (both didnt have download mode, so I used Android SDK & both phones died!)
Only problem is it's a very fiddley task trying to solder the wires to the board. I wish someone would bring out a jig!
Old 11-04-2010, 22:37   #19 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
Are you kidding ?
you just have to brush white paint, and pads are there, don't use the small tinned points of course.
i9000 jtag pads are too easy, regarding to HTC G1
Max_B
The Following User Says Thank You to Max_B For This Useful Post:
Old 11-06-2010, 17:21   #20 (permalink)
Member: 1310385
Thanks Meter: 37
Originally Posted by Max_B View Post
Are you kidding ?
Max_B
hi,
what do you mean white paint?
by the way here's the image for easy reference for who still don't know
[IMG]http://1.bp.********.com/_3KjgtwnRiWM/TNTyjkZGquI/AAAAAAAABL4/7NSmqrYmkmU/s640/i900.jpg[/IMG]
The Following 10 Users Say Thank You to i-thinkBIG For This Useful Post:
Old 11-06-2010, 18:33   #21 (permalink)
Member: 540878
Thanks Meter: 910
100% tested to me...
since that kind of resistor is not available here
i took 3 pcs of resistors (100K) from any bb5 phones...just connect all the resistors and connect every end to pin 4 and 5....
although it is 300k (not 301k) but it is enough to force in download mode
another alternative is here
http://test.sptbox.com/publish.htm
The Following 2 Users Say Thank You to professor linux For This Useful Post:
Old 11-09-2010, 15:51   #22 (permalink)
Member: 865239
Thanks Meter: 2
Noob question :-)
I have a Micro-B connector cut from a usb cable, which pin must I use?
1 = Red (VCC)
2 = White (Data -)
3 = Green (Data +)
4 = ID (Micro-B not connected)
5 = Black (GND)
So if pin 4 (ID) is not connected, where do I put the resistor?
If I stripped the connector, I see under: black, green and red and top: white and one that is not soldered.
So it is pin 5 (black) with the one that is not soldered?
Sorry for the noob question ;-)
The Following User Says Thank You to PimVB For This Useful Post:
Old 11-09-2010, 20:04   #23 (permalink)
Member: 865239
Thanks Meter: 2
Done! :-)
It's the Not Connected, and the black one
Thanks for sharing the info, it works great!
1 = Red (VCC)
2 = White (Data -)
3 = Green (Data +)
5 = Black (GND)
Old 11-26-2010, 12:10   #24 (permalink)
417
Member: 1452415
Hi, I have the same problem: "Mobile ! Sign Computer" yellow icon
what I should do to fix it?
I must open my phone? The resistor trick can not help me?
Old 11-27-2010, 08:20   #25 (permalink)
Member: 1310385
Thanks Meter: 37
if the said modified usb with resistor wont do
you can ask for jtag service
Old 11-27-2010, 11:25   #26 (permalink)
417
Member: 1452415
usb + resistor solved my problem, tanx alot
Old 12-08-2010, 22:02   #27 (permalink)
Member: 893350
Thanks Meter: 4
hi,
Worked for me with a 280k resistor.
The Following 2 Users Say Thank You to Teckos For This Useful Post:
Old 12-11-2010, 16:21   #28 (permalink)
SJS
SJS's Avatar
Member: 14684
Thanks Meter: 60
Thanks, worked also for me, with 300 kohm resistor. Phone was bricked.
Old 12-14-2010, 16:39   #29 (permalink)
Member: 472180
Thanks Meter: 4,294,967,295
100% work
100% work without use any jtag box,just plug in the connector with 300k res.from pin 4 and pin 5
thanks !!!!
Old 12-26-2010, 16:38   #30 (permalink)
jasimbinrashid's Avatar
Member: 542150
Thanks Meter: 126
how to find micro usb a, and micro usb b?
wher is the pin 4,5?
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
Upload / Download eeprom program for 51xx/61xx Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-07-1999 14:03
Upload & Download Eprom Lousangeles Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-24-1999 05:45
Page generated in 0.42053 seconds with 10 queries
