Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 08-24-2015, 14:00   #46 (permalink)
Member: 2286240
sir any method of reflashing dead boot on gt-i8730
Old 09-07-2015, 12:50   #47 (permalink)
.:Towhid:.'s Avatar
Member: 304260
Sonork: 100.1593127
Thanks Meter: 355
Phone Repaired Successfully..........................
Old 09-17-2015, 12:01   #48 (permalink)
Crazy Poster
Member: 1681546
Thanks Meter: 2
Originally Posted by jamesjerss View Post
SamsungGalaxy S3 Neo GT-I9300I Dead Boot Repair
REQUIRMENTS
1) 16 GB SD card
2) Win32DiskImager
3) unbrick file
4) odin and stock firmware
Download Win32DiskImager
Download unbrick file
Download Odin
Download Stock Firmware
For 4 file repair firmware Search tis file I9300IXXUAND1_I9300IOJVAND1 in z3x support or HWK support
Procedure
1) install the Win32DiskImager
2) download and extract the debrick.zip u will find a debrick.img
3) insert sd card (16 GB class 4 or 10) and format it
4) open Win32DiskImager
5) open img file and write to sd card
6) after complete remove sd card from pc and insert it into your neo
7) insert back the battery and press vol down + home + power button
8) u will get into download mode
9) now remove your sd card from mobile
10) open odin and add your firmware and flash
Note:Test nd post result
Source:Xda Here
Download Stock Firmware link not work plz any fresh link
Old 09-28-2015, 18:28   #49 (permalink)
Crazy Poster
Member: 1400175
Thanks Meter: 19
tnx mr jamesjerss
link for Win32DiskImager :
Index of /disk1/disk1/download.sourceforge.net/pub/sourceforge/w/wi/win32diskimager/Archive
Old 10-12-2015, 14:36   #50 (permalink)
Member: 2135872
Thanks Meter: 9
help
pls send mediafair or 4shared linkk plssssssssssss
Old 10-12-2015, 15:37   #51 (permalink)
Crazy Poster
Member: 2345370
Thanks Meter: 11
Sent from my iPhone using Tapatalk
Old 10-12-2015, 15:38   #52 (permalink)
Crazy Poster
Member: 2345370
Thanks Meter: 11
Try this
Old 10-12-2015, 15:54   #53 (permalink)
Crazy Poster
Member: 2345370
Thanks Meter: 11
Mediafire link
http://sh.st/bx3ZL
Old 10-12-2015, 17:25   #54 (permalink)
Crazy Poster
Member: 2345370
Thanks Meter: 11
Bro
This file only i9300 not i9300i OK so be carefully
Best of luck
Old 10-31-2015, 19:04   #55 (permalink)
Member: 1387849
Sonork: 100.1623264
Thanks Meter: 15
samsung s3 neo i9300i restart
Download ful firmware frm hwk support..try the procedure for dead boot repair
hello bro i have a problem with neo i9300i when i on phone showing logo with full name anf going off phone not bootup welcome scren and then again i removed battery and agian try to on phone again shoung full name and off not bootup i also flashed all frimware flashing ok 100% but not booting welcome screen i also do wipe/data factory reset in recovery mod is ok
but not bootup
plz help
Old 11-18-2015, 23:00   #56 (permalink)
Medusin's Avatar
Member: 400280
Thanks Meter: 83
Hi guys I have same problem.. after unbrick with sd card... the phone ONLY POWER ON with SD UNBRICKER INSIDE!! If I remove the microsd phone goes to qualcom hs usb etc... How can I fix it?? Thnkx in advanced.
Old 12-19-2015, 10:37   #57 (permalink)
md jawad's Avatar
Member: 729723
Thanks Meter: 211
REQUIRMENTS
1) 16 GB SD card
2) Win32DiskImager
3) unbrick file
Download Odin
Procedure
Source:Xda Here
<ID:0/126> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> I9300IXXUAND1_I9300IOJVAND1_I9300IXXUAND1_HOME.tar .md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/126> Odin engine v(ID:3.1005)..
<ID:0/126> File analysis..
<ID:0/126> SetupConnection..
<ID:0/126> Initialzation..
<ID:0/126> Get PIT for mapping..
<ID:0/126> Firmware update start..
<ID:0/126> SingleDownload.
<ID:0/126> sbl1.mbn
<ID:0/126> NAND Write Start!!
<ID:0/126> aboot.mbn
<ID:0/126> rpm.mbn
<ID:0/126> tz.mbn
<ID:0/126> sdi.mbn
<ID:0/126> NON-HLOS.bin
<ID:0/126> boot.img
<ID:0/126> recovery.img
<ID:0/126> system.img.ext4
<ID:0/126> modem.bin
<ID:0/126> cache.img.ext4
<ID:0/126> hidden.img.ext4
<ID:0/126> RQT_CLOSE !!
<ID:0/126> RES OK !!
<ID:0/126> Remain Port .... 0
<OSM> All threads completed. (succeed 1 / failed 0)
<ID:0/126> Removed!!
100% succeed
Old 12-20-2015, 16:56   #58 (permalink)
Member: 1674096
Thanks Meter: 49
3) insert sd card (16 GB class 10) and format it
10) open odin and add your firmware and flash it
https://mega.nz/#!DVcSTA7R!0D0ah1pSa...6M2Ea0NmngPQX4
Old 12-27-2015, 04:16   #59 (permalink)
Member: 2501657
Bluetooth problem
Hi guys
I have sam star plus 2 (350E) & I have problem with bluetooth it does't work even after flash by odin
Old 01-11-2016, 07:36   #60 (permalink)
Member: 399781
Thanks Meter: 94
just boot repaired i9300i, and flashed with I9300IXXUBNH3_I9300IOXEBNH3_SKZ_Kazachstan_Android _4.4.4 using octoplus box,
thank you
Page generated in 0.27481 seconds with 8 queries
