Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 11-24-2015, 09:29   #1 (permalink)
Member: 2369894
Thanks Meter: 10
G920F no baseband after flash
G920F Unknown Baseband after flash with extracted tar firmware and then changed to MD5, flashed by Z3X
becuse, by odine and Z3X with stuck firmware I couldnt flash
i faced ERR
Old 11-24-2015, 23:06   #2 (permalink)
shahsoft's Avatar
Member: 2302076
Sonork: 100.1663298
Thanks Meter: 185
Flash modem.bin file and post the result
Sent from my iPhone using Tapatalk
Old 11-25-2015, 04:09   #3 (permalink)
Member: 2308583
Thanks Meter: 40
test repair efs then flash again if not done u must check ur emmc
Old 11-25-2015, 22:37   #4 (permalink)
Member: 1627353
Sonork: TWISTER 93179
Thanks Meter: 3
check the buyer code or which country efs on it first .if the software is germany and you used southafrica efs can develop that problem .. make sure your imei to know origin of the devicE,,
HYBOYZ
Old 11-25-2015, 23:18   #5 (permalink)
Member: 851193
Sonork: 100.1615313
Thanks Meter: 348
i faced ERR
Add me on yahoo
tomorrow morning will give flash file flash it
don't reset efs or anything.
Old 11-27-2015, 03:44   #6 (permalink)
Member: 1483268
Thanks Meter: 55
i have the same problem i flash modem and i do reset efs but no luck
Old 11-27-2015, 07:54   #7 (permalink)
kpkgsm's Avatar
Member: 2164664
Sonork: 100.1654214
Thanks Meter: 119
i faced ERR
give me your phone SN number I will try to find correct firmware for you bro
Old 11-27-2015, 08:15   #8 (permalink)
Member: 1756298
Thanks Meter: 3
i faced ERR
ic base band problem
Old 11-27-2015, 17:10   #9 (permalink)
Member: 1483268
Thanks Meter: 55
RF8G40C6RCX
thank you .
Old 11-28-2015, 11:07   #10 (permalink)
kpkgsm's Avatar
Member: 2164664
Sonork: 100.1654214
Thanks Meter: 119
Originally Posted by kassem109 View Post
RF8G40C6RCX
thank you .
BRO REcheck SN your sn here shows not supported
Old 11-28-2015, 17:23   #11 (permalink)
Member: 1483268
Thanks Meter: 55
Old 11-29-2015, 00:11   #12 (permalink)
Member: 1483268
Thanks Meter: 55
thank you all i fix it with custom rom
Old 04-04-2016, 17:58   #13 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
How did you do it ?
What custom ROM did you use ?
Old 04-05-2016, 00:32   #14 (permalink)
Member: 1483268
Thanks Meter: 55
Originally Posted by usernome View Post
How did you do it ?
just flash these file
https://forum.gsmhosting.com/vbb/****************************/?7xjsua97k6s63s4
The Following User Says Thank You to kassem109 For This Useful Post:
Old 04-06-2016, 17:32   #15 (permalink)
Member: 2191956
Thanks Meter: 3
TNX BRO
UNKNOWN BASEBAND ok whith this file and after that repairing imei
now everything is ok
Page generated in 0.25438 seconds with 8 queries
