Stuck at "Samsung Galaxy Note GT-N7100 my handest stuck at samsung galaxy note and download mode woking fine but recovery mode is not working i tr y hard with odein i change to file my prlbem is under i give pit to oden but failehttp://i61.tinypic.com/302c12x.jpg |
try repair boot and agen flash |
i tried everything boss same message disapair "fail" |
i seach alot i think it emmc is currpted or damged we need to change or program it |
Hi mates usually hang on logo , no product code... this matter is partition problem and it is hardware fault is in Emmc ic u have to change this ..but nowadays GPGEmmc box and Z3x has the solution for it u can try for it if not slve then u have to change Emmc ic and ur solution will be 100% solve........... |
plz guide how to do it cant find any where |
Same Problem Product Name is Black Also Having z3x & Riff How to Solve it ? |
http://tapatalk.imageshack.com/v2/14...f208a523c4.jpg Is any solution to change emmc? Sent from my ALCATEL ONE TOUCH 6040D using Tapatalk |
write EFS file on this problem 100% work |
No Pit Error 100% Emmc Fault Only Easy Jtag Repair http://i.imgur.com/7dBer9c.gif Br, ---------------- Raja Software |
File analysis... OK Total file size: 0x5D648520 (1494 Mb) Searching USB Flash Interface... detected COM28 Setup connection... OK Set PIT file... Error Done with Samsung Tool v.20.5 how to slove |
n7100 on recovery shows fail to mount system/ fail to mount efs (no such file or directory)..etc even odin fails to flash tried many firmwares anyone have solution plzzz post urgentlyyy.... thanks in advance |
http://s18.postimg.org/996un6zcp/screenshot_1.png i have this problem any solution i try many file with all odin tool and i chanj usb cable but same error |
my note 2 gt-n7100 isn't added in odin software when i plug with usb cable in pc after unplugged the jig cable! can i flash with debrick.img making special sd card? can you help me, please? i haven't box! smartphone is dead, no sound ecc.! |
