Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
09-28-2013, 10:53 | #1 (permalink) | ||
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | SAMSUNG S3(I9300)&GALAXY NOTE 2(N7100)Boot Reapir http://forum.gsmhosting.com/vbb/f777...-here-1696292/ 1)First Create Boot Card 2)Download teraterm-4.78 teraterm-4.78 3)Connect Spt Box Also Take One Micro Uart Cable 4)Open teraterm-4.78 (look the picture) Go To Device Manager Check Spt Port Number Open teraterm-4.78,Now New Window Apper. Select Spt Serial Port (look the picture) After Select The Serial Port Press Ok Button Next Go To Setup Click Serial Port Option Select Baud Rate 115200 Then Press Ok Button Insert Boot Card To Phone Connect Spt Via Uart Cable Then Insert Battery Next Hold Power Button Wait For Minutes Quote:
open spt software use any version flash file.but remmber must use repartition option then flash it are you used odin software must use mx pit file&repartition option after the flash phone must powered but imei is damaged just rebuild imei via z3x. Quote:
this casue not software bad EMMC this phone cant repair with any jtag,must change the EMMC THIS SOLUTION FROM SAMSUNG OFFICIAL TEAM | ||
The Following 22 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
09-28-2013, 11:35 | #6 (permalink) | |
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
but they cant post any where cuz they promote the emmc boot repair box im tesed many times.i f you have phone you also test wait for the report | |
09-28-2013, 12:25 | #9 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Yes sure . 1 solution in many ways . and u Correct about any way Rules are rules |
The Following 3 Users Say Thank You to Mohsin-* For This Useful Post: |
09-28-2013, 13:02 | #11 (permalink) | |
No Life Poster Join Date: May 2007 Age: 37
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | Quote:
09-29-2013, 21:30 | #13 (permalink) |
No Life Poster Join Date: Sep 2006 Location: India
Member: 350719 Status: Offline Sonork: 100.1623850 Thanks Meter: 158 | TN default <OK> <OK> [DVFS] INT(1) : 0 DRAM Type : LPDDR2 16G [DVFS] MIF(3) : 0 [EPLL][VPLL][CLK_DIV] OK <OK> [LOCK SW/HW]ARM:0/0 INT:0/0 G3D:0/0 MIF:0/0 SHIFT:0/0 [DVFS] ARM(0) : 5 [DVFS] INT(1) : 0 [DVFS] G3D(2) : 0 [DVFS] MIF(3) : 0 [SD_INIT SDMMC_HighSpeedONE] SD_READ: 20000 20000 0x40008000 -> 572710 usec <OK> Inp32(uAddr) : 0xea00007e FW Booting [Patch Stop] This is not Rom Cod n7100 i9300 boot file same.. |
09-29-2013, 21:45 | #14 (permalink) | |
Freak Poster Join Date: Aug 2006 Location: 202.43.163.90
Member: 323742 Status: Offline Thanks Meter: 73 | Quote:
I never success repair boot N7100 | |
