Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
03-09-2014, 22:37 | #1 (permalink) |
No Life Poster Join Date: Feb 2014
Member: 2136780 Status: Offline Thanks Meter: 68 | Samsung I9300 & N7100 Dead Boot Solution & IMEI Null Solution [Available] Samsung s3 i9300 & Note2 N7100 Dead boot repair solution & imei null solution only for i9300 Credits go to jamesjerss, original author of this post which been copied here from another forum Procedure: * Download samsung s3 boot card maker SAMSUNG_S3_BOOT_CARD_MAKER Or samsung s3 boot card maker.rar * Extract it on desktop * Take a card reader insert memory card into the card reader nd connect it to the pc * From the extracted folder run Diskdump2.exe * Select generic storage Device. pictures below follw it * Now to write the scripts folle the below given picr Now done yu are successfully created Dead boot memory-card To continue further Requirements: * Z3X Samsung Box or SPT Box (i used z3x) * special UART Cable (300k or 500k uartcable) * Download teraterm-4.78 From Here * Fully charged battery Dead boot Reapairing procedure * Download nd extract teraterm-4.78 on desktop * From extracted folder run ttermpro.exe there select serial port nd change the serial port to z3x serial port lik below givin in the picr *After Select The Serial Port Press Ok Button den Go To Setup Click Serial Port Option Select Baud Rate 115200 Then Press Ok Button lik below givn in the picr * Now insert the created boot card to the mobile * Connect the Uart cable via z3x box * Now Insert the battery nd wait for 5min if the procces didnt start discnnt the mobile close ttermpro agin try it. * if it run success yu vil the result below given lik this. Quote: Code: pit_check_integrity: invalid pit.(0x0) pit_check_integrity: invalid pit.(0x0) update_guid_partition_table: There is no pit binary. fsd_reclaim 1283: MST is not recognized(mst.magic=0x0) fsd_reclaim 1284: MST is not recognized fsd_reclaim 1599: Error(nErr=0x0) fsd_reclaim 1604: j4fs_rw_start is set to default value(128KB) j4fs_open 153: Error(nErr=0x40000000) j4fs_read_file_bootloader 355: j4fs panic load_j4fs_param: 'param.j4fs' does not exist, make new one.. j4fs_write_file_bootloader 184: j4fs panic fail j4fs_read_file_bootloader 355: j4fs panic load_j4fs_param: debug level file does not exist..*INCORRECT!* init_fuel_gauge: battery is not detected, do not init fuelgauge init_microusb_ic: MUIC: CONTROL1:0x1b init_microusb_ic: MUIC: CONTROL1:0x1b init_microusb_ic: MUIC: CONTROL2:0x3b init_microusb_ic: MUIC: CONTROL2:0x3a PMIC_ID = 0x2 PMIC_IRQSRC = 0x0 PMIC_STATUS1 = 0x10 PMIC_STATUS2 = 0x0 PMIC_PWRON = 0x2 PMIC_IRQ1 = 0x27 PMIC_IRQ2 = 0x0 s5p_check_keypad: keypad value=0x0 s5p_check_reboot_mode: INFORM3 = 0 ... skip s5p_check_upload: MAGIC CODE=d1b0f038 microusb_get_attached_device: STATUS1:0x3c, 2:0x0 s5p_check_download: update mode=0 j4fs_read_file_bootloader 355: j4fs panic s5p_check_tzsw: invalid tzsw type! dummy? scr_draw_image: draw 'download_error.jpg'... j4fs_read_file_bootloader 355: j4fs panic read_param_file: 'download_error.jpg' j4fs read failed! fimd_div:13, div:1, FB_SOURCE_CLOCK:800000000, FB_PIXEL_CLOCK:57153600 a2, 60, 90, * if yu get this error at the end [Patch Stop] This is not Rom Code. yu cant fix yur mobile yu have to change yur emmc chip Quote: Code: TN default <OK> <OK> [DVFS] INT(1) : 0 DRAM Type : LPDDR2 8G [DVFS] MIF(3) : 0 [EPLL][VPLL][CLK_DIV] OK <OK> [LOCK SW/HW]ARM:0/0 INT:0/0 G3D:0/0 MIF:0/0 SHIFT:0/0 [DVFS] ARM(0) : 5 [DVFS] INT(1) : 0 [DVFS] G3D(2) : 0 [DVFS] MIF(3) : 0 [SD_INIT SDMMC_HighSpeedONE] SD_READ: 20000 20000 0x40008000 -> 668484 usec <OK> Inp32(uAddr) : 0xea00007e FW Booting [Patch Stop] This is not Rom Code. * After done this yur mobile must me n download mode or white screen if white screen manually put into download mode. * After dead boot repair mine white screen i manually put into download mode pir below * Now update your mobile with factory firmware with PIT file lik below given n the picr.Factory firmware Download Here * After update complete yur mobile may not have imei .imei null or yur mobile will not boot bcoz of dead boot repair. yur efs must be corrupted * To Fix this prob first root yur mobile Download from here CF-Auto-Root-m0-m0xx-gti9300.zip (flash it through odin select as odin) * Now Download this EfS repair file nd flash it through odin select as odin yur mobile must boot but the imei become lik this 004999010640000 I9300_Repair_efs.tar I9300_Repair_efs.zip * if yur imei is null yu cant repair using this box so 1st yu have to repair the efs using above givn file. if yur imei bcome lik tis oly (004999010640000) you can repair using z3x or other Samsung tool * Now follw the picr to repair imei problem. * After IMEI Repair Credits go to jamesjerss, original author of this post which been copied here from another forum Last edited by ...:::::NP™:::::...; 04-14-2017 at 20:11. Reason: Download link has been updated |
The Following 10 Users Say Thank You to mike_shinoda For This Useful Post: |
03-12-2014, 02:03 | #8 (permalink) |
Freak Poster Join Date: Feb 2013 Location: India
Member: 1886939 Status: Offline Sonork: 100.1650305 Thanks Meter: 78 | But will this repair product code also in my case now mobile working fine as your process but still no product code n in call mic not working due to this |
05-04-2014, 09:14 | #10 (permalink) |
Junior Member Join Date: Apr 2011 Location: madanapalle
Member: 1563878 Status: Offline Sonork: 100.1638814 Thanks Meter: 0 | MoviNand Initialization Complete! Samsung S-Boot 4.0-20120315.12195 8) EXYNOS4412(EVT 2.0) / 1023MB / Re pit_check_integrity: invalid pit. pit_check_integrity: invalid pit. update_guid_partition_table: Ther fsd_reclaim 1283: MST is not reco fsd_reclaim 1284: MST is not reco fsd_reclaim 1599: Error(nErr=0x0) fsd_reclaim 1604: j4fs_rw_start i j4fs_open 153: Error(nErr=0x40000 j4fs_read_file_bootloader 355: j4 load_j4fs_param: 'param.j4fs' doe j4fs_write_file_bootloader 184: j fail j4fs_read_file_bootloader 355: j4 load_j4fs_param: debug level file init_fuel_gauge: fuelgauge power init_fuel_gauge: POR status fuelgauge_por: POR start: vcell(3 fuelgauge_por: update SDI paramet fuelgauge_por: RCOMP(0x87), TEMPC fuelgauge_por: POR finish: vcell( get_table_soc: vcell(3611) is cac init_fuel_gauge: start: vcell(361 init_fuel_gauge: finish: vcell(36 ) init_microusb_ic: MUIC: CONTROL1: init_microusb_ic: MUIC: CONTROL1: init_microusb_ic: MUIC: CONTROL2: init_microusb_ic: MUIC: CONTROL2: PMIC_ID = 0x2 PMIC_IRQSRC = 0x0 PMIC_STATUS1 = 0x10 PMIC_STATUS2 = 0x0 PMIC_PWRON = 0x2 PMIC_IRQ1 = 0x7f PMIC_IRQ2 = 0x0 s5p_check_keypad: keypad value=0x s5p_check_reboot_mode: INFORM3 = s5p_check_upload: MAGIC CODE=c8c0 microusb_get_attached_device: STA s5p_check_download: update mode=0 j4fs_read_file_bootloader 355: j4 s5p_check_tzsw: invalid tzsw type scr_draw_image: draw 'download_er j4fs_read_file_bootloader 355: j4 read_param_file: 'download_error. fimd_div:13, div:1, FB_SOURCE_CLO [ERROR:LCD] s6e8ax0_read_id : s6e |
05-06-2014, 18:26 | #14 (permalink) |
No Life Poster Join Date: Jan 2008 Location: in Your Heart :)
Member: 681758 Status: Offline Sonork: 100.1676160 Thanks Meter: 347 | its very long process , no need here z3x box for write file after creat sdcard you just need you put your sdcard in phone also put download usb jeck then you see after 1 mint download mode on screen 2 flash included pit 3 repair imei on z3x , spt 4 enjoy :::::HusSain :::: |
05-06-2014, 20:52 | #15 (permalink) | |
No Life Poster Join Date: Sep 2005 Age: 41
Member: 185279 Status: Offline Thanks Meter: 43 | Quote:
Where can I find it ? | |
