Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
09-07-2014, 18:13 | #1 (permalink) |
No Life Poster Join Date: Jul 2010 Location: india nug jalalpur
Member: 1345926 Status: Offline Sonork: 100.1671229 Thanks Meter: 176 | samsung I9100 dead...... Samsung I 9100 dead no downlode mode no recovery mode no show charging chek charging supply ok but set not on . plz. help arjent . |
09-08-2014, 19:36 | #5 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
GT-I9100 Galaxy S2 Repair Dead Boot
Repair File Download http://www.ort-jtag.com/Files/ups/GT-I9100.rar or GT-I9100.rar - FileFactory Compatibility Omnia Repair Tool (ORT) JRT for SMTI RIFF Box JTAG Medusa JTAG Box and other devices using JTAG and supporting this model. Usage Notes 90% of i9100 does not have molex connector (ribbon connector) fitted on the phone board. If this is the case and your board doesn't have this connector installed, you need to solder a molex connector to the board first as on shown picture below. It's much easier to do this than soldering ultra-thin wires After this you can connect JTAG adapter to the soldered molex connector and perform your Jtag repair as shown on the video below. https://www.youtube.com/watch?featur...&v=GyiXtFVh6KE | |
09-09-2014, 03:00 | #7 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | There is an solution for eMMC Bricked phones ! Kernel for boot from sdcard Download the patched kernel and extract the boot.img From it , now place this boot.img in the rom you want to flash and replace the Boot.img of the Rom. This step is necessary because the Kernel which is included in Rom arent patched, so your phone maybe wont flash the file correctly. you have to partition your sd card first, as first partition you need an fat32 user data partition ( there will stored your music, videos,...) and as second partition an ext4 2GB partition for /data , if you done that, flash the kernel and if all goes well boot in recovery and try to do a factory reset and post what happens ! Download the basic version for free here : Easeus Partition Master - Download - CHIP Kernel Download: Download AriesLG from SourceForge.net 1. Download this app --> https://play.google.com/store/apps/d...oid.emmc_check 2. There are many informations, but only the third box and the row "Type" are important, so look what its written next to "Type" 3. If their stands 'SEM08G', you can relax, your chip isnīt a known eMMC Bug chip, you dont need to change anything, the TuT end here for you. But if their stands 'M8G2FA' I have bad news for you, your Device are vulnerable and you need to check if its save already or if you need to make it save. 4. Now you have to know which recovery you have. If you don`t know, skip this step. Are you using Ivendors cwm 6.x.x ? or cwmTouch? or the 3.x Kernel based TWRP from buffo ? Then you have to continue with this TuT ! if you are using cwm 5.x.x or TWRP 2.2.1, you dont need to do anything because these recoveries are save because their base on 2.6 Kernel 5. If you have one of the 'Bad' recoverys, just install one of the 'good' one ! I recommend TWRP v.2.2.1 because its a known Stable and easy to use Recovery without any Bugs. For all who want the newest version of Recovery or want to use only CWM, theyr are TWRP v.2.5 and a new Version of Ivendors CWM 6 6. Just download the recovery that you want (if you dontīt know, choose TWRP 2.2.1) from below and put the .zip file on your SD Card 7. Boot in recovery mode and install the new recovery but DONīT WIPE ANYTHING !! or your phone can Brick ! For all the people who want to flash the recovery trough Odin, I will link the Odin versions below too. 8. After flashing the new recovery, just reboot, shutdown and reboot into recovery, now you can do anything without risk of Bricking ! CWM 5.5.0.4 Recovery flashable zip : Home Button to select : Dev-Host - CWMRecovery-5.5.0.4-ariesve.zip - The Ultimate Free File Hosting / File Sharing Service Menu Key to select : Dev-Host - CWMRecovery-5.5.0.4-menu-ariesve.zip - The Ultimate Free File Hosting / File Sharing Service |
