Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 10-26-2018, 11:16   #1 (permalink)
Albelektronik's Avatar
Member: 178513
Thanks Meter: 109
Samsung S8 G950F FRP Binary 4 Combination
Hello everyone,
I got this S8 G950F it's have OREO binary 4
DO you have any solution for binary 4 combination file to bypass FPR?
I got a link as well in YouTube but the phone is blacklisted so the solution will not work for me.
It might be helpful to someone else: http://www.youtube.com/watch?v=yz1Ekw3wWy8
Regards, Carmelo.
Last edited by ...:::::NP™:::::...; 10-26-2018 at 19:00. Reason: YouTube view on the forums.
The Following User Says Thank You to Albelektronik For This Useful Post:
Old 10-26-2018, 11:46   #2 (permalink)
Member: 2613252
Thanks Meter: 1,833
Originally Posted by Albelektronik View Post
Hello everyone,
It might be helpful to someone else: https://www.youtube.com/watch?v=yz1Ekw3wWy8
Regards, Carmelo.
Hello, if you need the combination g950f binary 4 you can find it here at this link.
COMBINATION_FA70_G950FXXU4ARI1_CL12792727_QB198416 86_REV00_user_mid_noship.tar.md5.rar
Download:
The Following 2 Users Say Thank You to amleto90 For This Useful Post:
Old 10-26-2018, 12:11   #3 (permalink)
Member: 178513
Thanks Meter: 109
Thank You very much Amleto90 Work in progress...
Old 10-26-2018, 17:56   #4 (permalink)
Member: 178513
Thanks Meter: 109
Yes combination is perfectly fine, I'm not able to remove FRP any help? I have OEM Lock ON as well.
Thanks friends.
Old 10-26-2018, 18:11   #5 (permalink)
Star75's Avatar
Member: 53198
Sonork: 100.1589499
Thanks Meter: 818
Thanks friends.
No need combination, no need flash anything : http://forum.gsmhosting.com/vbb/f777.../#post13359784
The Following User Says Thank You to Star75 For This Useful Post:
Old 10-26-2018, 18:42   #6 (permalink)
Member: 2613252
Thanks Meter: 1,833
Thanks friends.
hello if you can come in handy this post you can read and if you have octopus box or z3x or you can use the hush sms method in the post there are links in description
http://forum.gsmhosting.com/vbb/f684...40/index2.html
Old 10-26-2018, 18:44   #7 (permalink)
Member: 178513
Thanks Meter: 109
Thanks guys for your prompt help. Problem is the phone blacklisted and locked in 3 UK so this method will not work.,
Old 10-26-2018, 18:53   #8 (permalink)
Member: 2613252
Thanks Meter: 1,833
[QUOTE=Albelektronik;13384376]Thanks guys for your prompt help.
Read the link of the post that I wrote above, without using the method the hush sms method, using the combination and what you have to do
if you use the first method install the combination via box via adb reset the frp do the hard reset of the phone then from active developer options the voices unlock and usb debugging do another factory reset and then flash the firmware of 3 single files ap, bl, and home_csc do not use csc but home _csc in case it does not succeed the reset operation frp pass to the second method as written in the link of the post above
Old 10-29-2018, 13:02   #9 (permalink)
Member: 178513
Thanks Meter: 109
[QUOTE=amleto90;13384383]
I don't have octopus to do that, only Chimera at the moment.
Can it be done with odin and chimera something?
Old 10-29-2018, 13:47   #10 (permalink)
Member: 2613252
Thanks Meter: 1,833
[QUOTE=Albelektronik;13388074]
with chimera you can flash the firmware, but you do not have the frp reset option via adb for g950f, but you can try to select another model like g925f or g935f that supports the frp reset operation via adb once the combination is installed, before what operation did you perform to reset the frp when you installed the combination as you flashed the stock firmware in 4 files or in 3 files?
Old 10-29-2018, 17:27   #11 (permalink)
Member: 178513
Thanks Meter: 109
Good idea i will try to chose a different model on chimera.
Yes basically i have a stock firmware with 4 files, i tried the home on csc but it's terminated with error regarding the hidden file.
I'm trying Chimera FRP Reset.
Thanks for the patience and help.
Regards, Carmelo.
Old 10-29-2018, 17:36   #12 (permalink)
Member: 178513
Thanks Meter: 109
[QUOTE=amleto90;13388150]
No luck, Chimera is recognising the model it's says mismatch.
Even it's not was supported up to binary 2
Old 10-29-2018, 17:38   #13 (permalink)
Member: 2613252
Thanks Meter: 1,833
[QUOTE=Albelektronik;13388563]
when you installed the combination you enabled debugging usb and oem unlock from developer options and made a factory reset and then you tried to write in 4 files or in 3 files ie ap, cp, bl, and csc or you used csc_home or 3 ap file, bl, csc or csc_home the firmware?
In case you have not tried make the flash of the firmware files in 3 files use, ap, bl and csc_home do not use csc
f you have z3x try to select another model like g935f and reset frp via adb with the installed combination
Old 10-29-2018, 17:40   #14 (permalink)
Member: 178513
Thanks Meter: 109
[QUOTE=amleto90;13388567]
On combination firmware i hve activated usb debug, (Was anyway active) OEM Lock is not in the menu at all, I activated ADB as well, I have not follow the factory reset from combination.
I'm trying.
Old 10-29-2018, 17:45   #15 (permalink)
Member: 2613252
Thanks Meter: 1,833
[QUOTE=Albelektronik;13388569]
I'm trying.
as soon as you reset, try to write the stock firmware in 3 files ap-bl-csc_home
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.22093 seconds with 8 queries
