Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 10-29-2018, 18:14   #16 (permalink)
Albelektronik's Avatar
Member: 178513
Thanks Meter: 109
Same error hidden file is larger
Old 10-29-2018, 18:26   #17 (permalink)
Member: 2613252
Thanks Meter: 1,834
Try using Odin to the latest version and flash the firmware in 3 files AP, BL, csc_home see if it gives you the same error.
What firmware did you use to do the flash, you can write here the PDA and CSC
In the screenshot of Chimera have you selected the model g935f to do the flash?
Old 10-29-2018, 18:32   #18 (permalink)
Member: 178513
Thanks Meter: 109
Odin the same
I'm using the original firmware for this model based on serial number of the phone, chimera suggest this firmware as original and it's locked in 3 UK.
AP_G950FXXU4CRI5_CL14315050_QB19732135_REV00_user_ low_ship_meta.tar
BL_G950FXXU4CRI5_CL14315050_QB19732135_REV00_user_ low_ship.tar.md5
CP_G950FXXU4CRI1_CP10677719_CL14315050_QB19622395_ REV00_user_low_ship.tar.md5
CSC_H3G_G950FH3G4CRI1_CL14315050_QB19634351_REV00_ user_low_ship.tar.md5
HOME_CSC_H3G_G950FH3G4CRI1_CL14315050_QB19634351_R EV00_user_low_ship.tar
I have try a new way but it seems not work as well as in attachment.,
I renamed the home .tar and extracted, cancelled the hidden file inside, compress again with 7-zip with extection .tar and renamed tar.md5
This time it's says not is larger but it's skipped this file.
Flash go thrue withut error
Firmware update started
Selected model: SM-G950F
Processing firmware...
Flashing firmware...
Waiting for download mode.
Connecting.
SBL Info: Model: SM-G950F, Region: EUR, Provider: OPEN, PDA: G950FXXU4CRI5
Reading PIT from phone.
File HOME_CSC_H3G_G950FH3G4CRI1_CL14315050_QB19634351_R EV00_user_low_ship/cache.img entry is not found in the PIT. Skipped.
Flashing boot.img
Flashing recovery.img
Flashing system.img
Flashing userdata.img
Flashing sboot.bin
Flashing param.bin
Flashing up_param.bin
Flashing cm.bin
Flashing modem.bin
Flashing modem_debug.bin
Restarting phone.
Successfully finished.
Finished at local time: [10.29.18 17:34:17]
WorkID: 46641070
Old 10-29-2018, 18:34   #19 (permalink)
Member: 93421
Thanks Meter: 19
But anyway that removed the FRP not the fact that this in a blacklist, so if you have blocked the IMEI, then remain blocked. Now if you just need to remove the Google account do it with Odin as you say Amleto90 as you need nothing more
Old 10-29-2018, 18:37   #20 (permalink)
Member: 2613252
Thanks Meter: 1,834
Odin the same
Connecting.
Flashing boot.img
Flashing system.img
Flashing sboot.bin
Flashing param.bin
Flashing cm.bin
Flashing modem.bin
Restarting phone.
WorkID: 46641070
try to use odin to the latest version 3.13.1
flash 3 file ap, bl, csc_home
Old 10-29-2018, 18:38   #21 (permalink)
Member: 178513
Thanks Meter: 109
Even after this try with mod HOME FRP still there.
Is very strange
I'm not worry about the black list I just want to remove FRP
Thanks
Old 10-29-2018, 18:46   #22 (permalink)
Member: 2613252
Thanks Meter: 1,834
Is very strange
Thanks
but also to use odin and doing the flash of 3 files ap, bl, csc_home you stay frp on?
Old 10-29-2018, 18:56   #23 (permalink)
Member: 178513
Thanks Meter: 109
Odin fail as well it's something wrong with this.
Old 10-29-2018, 19:05   #24 (permalink)
Member: 2613252
Thanks Meter: 1,834
using chimera you can deselect the entries from ap
if chimera can not deselect the test items use 7zip and delete them by removing
recovery.img "," cache.img ", and" userdata "partitions.
and then try to flash the firmware, if in the case of error try to download
Try using another firmware that is always the same binary 4 but different country or that does not have the brand of h3g
or try to follow this guide, not having you ocotpus software that can reset the frp via adb see if it works
https://www.hardreset.info/devices/s...ung-android-8/
The Following 2 Users Say Thank You to amleto90 For This Useful Post:
Old 10-29-2018, 21:10   #25 (permalink)
Member: 178513
Thanks Meter: 109
Any other way... crazy
Old 10-29-2018, 21:11   #26 (permalink)
Member: 178513
Thanks Meter: 109
Followed exactly as described, it's says success for FRP with combination firmware, once flashed with stock asked account again. It's so strange this phone...
Old 10-29-2018, 21:20   #27 (permalink)
Member: 178513
Thanks Meter: 109
It's says FRP unlocking success but still not.
Old 10-29-2018, 21:28   #28 (permalink)
Member: 178513
Thanks Meter: 109
I think all this because is OEM Lock... or becuase is binary 4 (u4)
Old 10-29-2018, 21:47   #29 (permalink)
Member: 2613252
Thanks Meter: 1,834
when you wrote the combination and use the program frp reset via adb, write the firmware by removing these entries by selecting the entry ap,
recovery.img "," cache.img ", and" userdata "partitions., then write the firmware in 4 files with csc_home, but you have to remove the three entries that I wrote I use chimera or remove them using 7 zip
try using this apk from this site there are instructions
https://www.techeligible.com/2018/06...alaxy-s8-plus/
Old 10-30-2018, 00:05   #30 (permalink)
Member: 2816318
Thanks Meter: 8
Very good sir ... working file
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.21376 seconds with 8 queries
