samsung Sm-A510fd FRP lock remove ..help needed hello friend i have sm-a510fd frp locked ..... i did try with many methods and many tools but still no luck i tried with ..z3x..octoplus no support please help me |
Due to the new security released by Samsung, Now we can't bypass the FRP with the known ways, So, you can do the following to bypass the FRP in your device, Download the OL9 FW from here, Unpack and remove modem.bin file, Then Repack the FW again, For that you can use TAR_MD5_PACKAGER, Now just flash the modified FW with Odin, After that you can use any box or method to bypass the FRP, When you're done with FRP just flash the device with the latest FW again. I'v done that alot with J7 and J5 devices and it should also work for your device. BR |
I have done but failed you can help me file my Galaxy A5 - SM-A510F is not thank you very much ps: sorry for my english is not good |
write this firmware TUR-A510FXXU1AOL1-20151223202310 after use ur brains |
Follow this.. I did it Frp |
NO CONFUSED NO WAST TIME JUST DOWNLOAD THIS FILE AND DIRECT FLASH AFTER RESET FRP USE ANY TOOL (Z3X,OCTOPUS,BST,......} THEN UPDATE VIA SMART SWITCH USE BACK STICKER S/N DON"T FORGET PRESS THANK BUTTON HARE FILE:A510FXXS3BPIA_A510FOJV3BPI1 |
HIIII :o:o BROOOO.. I HAVE A A510FD SAMSANG FRF SOLTUSION THIS FILE |
after flashing with this file, if you try to remove frp with any tool like z3x, chimera tool or octopus box, phone will not switch on properly, phone will start blinking after restart, so this isn't working solution for new security.. |
i think to use octopus box a510f frp best suport in tha world try this box 100% solution tested by me sorry my english |
Use z3x box to remove frp lock. |
can u plzz help me to remove frp by z3x box |
