Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
10-08-2017, 10:33 | #1 (permalink) |
Insane Poster Join Date: Oct 2017 Location: pakistan
Member: 2765181 Status: Offline Thanks Meter: 70 | Samsung SM-G5528 Playstore Fix File Free. Here Is File SM-G5528_PlayStore fix File Tricks By combinefile.com.rar Password PHP Code: Last edited by ...:::::NP™:::::...; 10-08-2017 at 20:56. Reason: Remove has been redirected URL link from password . |
10-08-2017, 10:41 | #2 (permalink) |
Member: 2765181 Status: Offline Thanks Meter: 70 | Password www. combinefile. com Use Password Without Spaces. Always Follow The Rules |
The Following 2 Users Say Thank You to Hussain110 For This Useful Post: |
10-08-2017, 20:04 | #4 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | I downloaded the file but not tested yet... It is Odin flashable.. There is a txt file that says: there is trick to flash it Step 1- first flash These Files, set will blink, Step2- go to recvoery reset user data and reset cache Step3- then start set in download mode then flash again |
10-09-2017, 06:11 | #5 (permalink) |
Member: 2765181 Status: Offline Thanks Meter: 70 | If Link Not Working Here is Link Download SM-G5528_20051_PlayStore fix By **********.rar | Marhaba Firmware |
10-18-2017, 16:34 | #6 (permalink) |
No Life Poster Join Date: Apr 2008 Location: karachi .. Age: 38
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | @voltron2008 you are so informative man.i like your tips from so much time.you helped me in past many times. can you suggest me any other trick? |
10-18-2017, 19:19 | #10 (permalink) |
Member: 861795 Status: Offline Thanks Meter: 1,275 | It stucks at what stage? did you followed the steps in txt file: "there is trick to flash it Step 1- first flash These Files, set will blink, Step2- go to recvoery reset user data and reset cache Step3- then start set in download mode then flash again" |
10-19-2017, 13:29 | #12 (permalink) | |
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | Quote:
system.img.ext4 and then nothing happen. even not fail and no done.just stuck | |
