Samsung SM-J710GN FRP remove done... Samsung SM-J710GN FRP remove successful.. we just need a good wifi connection.. put the frp apks on the sdcard (GAM6.apk/Quickshortcut.apk).. follow the image guide below good luck... Guide 01 http://www.mediafire.com/convkey/fab...rck3v00b4g.jpg Guide 02 http://www.mediafire.com/convkey/a72...w306bafx4g.jpg Guide 03 http://www.mediafire.com/convkey/b68...g1g1oegl4g.jpg Guide 04 http://www.mediafire.com/convkey/729...3k7bf5lz4g.jpg Guide 05 http://www.mediafire.com/convkey/a11...5s5ke8sp4g.jpg Guide 06 http://www.mediafire.com/convkey/967...3n8zrnvr4g.jpg Guide 07 http://www.mediafire.com/convkey/5c8...g4oiwccc4g.jpg Guide 08 http://www.mediafire.com/convkey/da9...x9788u0h4g.jpg Guide 09 http://www.mediafire.com/convkey/61b...w2qxhuf24g.jpg Guide 10 http://www.mediafire.com/convkey/690...os1323964g.jpg |
continuation... Guide 11 http://www.mediafire.com/convkey/538...1jmbbvmj4g.jpg Guide 12 http://www.mediafire.com/convkey/4eb...bb5ccqmq4g.jpg Guide 13 http://www.mediafire.com/convkey/eb8...rfc9ee684g.jpg Guide 14 http://www.mediafire.com/convkey/a39...r7fqp18d4g.jpg Guide 15 http://www.mediafire.com/convkey/779...36410cv24g.jpg Guide 16 http://www.mediafire.com/convkey/e65...u447uy7p4g.jpg Guide 17 http://www.mediafire.com/convkey/5fd...x97vt03m4g.jpg Guide 18 http://www.mediafire.com/convkey/fac...ohjbxuxb4g.jpg done.... |
;););););););)thanks you |
Gracias salio al 100 |
j710gn frp Quote:
very lengthy procedure brother. follow very short and quick even andriod 7.0 1.open odin v3.11 2.select cp tab 3.open and select exynos 4.put dnload mode 5.start and done may show an error occured etc msg in first attept then again repeat will be clear in 2nd attept.FRP done. |
Thanks bro it is work for me...*** bless you |
so taffffffffffffffffffffffffffffffffffffffffffff |
Welcome to Octoplus Box Samsung software version 3.0.0 Card S/N : ----------------------------------------------------------------------------------- To connect SM-J710F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J710GN phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- WorkID: 000CB618 Platform: Samsung Android Selected port: COM1 Selected model: SM-J710GN Operation: Reset FRP - UART EMMC Searching for UART interface.. COM4 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation...OK Searching for UART interface.. COM4 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock (1/4 attempt)..success FRP / Reactivation lock is successfully reseted! Performed by 3.0.0 Software version. |
