Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
![]() | #5 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2008 Location: GSM,Pakistan
Member: 811049 Status: Offline Thanks Meter: 32 | j710gn frp Quote: very lengthy procedure brother. follow very short and quick even andriod 7.0 1.open odin v3.11 2.select cp tab 3.open and select exynos 4.put dnload mode 5.start and done may show an error occured etc msg in first attept then again repeat will be clear in 2nd attept.FRP done. | |
![]() | #8 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2010 Location: pakistan Age: 45
Member: 1275418 Status: Offline Thanks Meter: 419 | Welcome to Octoplus Box Samsung software version 3.0.0 Card S/N : ----------------------------------------------------------------------------------- To connect SM-J710F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J710GN phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- WorkID: 000CB618 Platform: Samsung Android Selected port: COM1 Selected model: SM-J710GN Operation: Reset FRP - UART EMMC Searching for UART interface.. COM4 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation...OK Searching for UART interface.. COM4 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock (1/4 attempt)..success FRP / Reactivation lock is successfully reseted! Performed by 3.0.0 Software version. |
