samsung t567v knox enrollment please how i can solve my problem in tab samsung t567v knox enrollment problem . what is this problem ...how i can solve it . i tried to factory reset from the setting and from the recovery but the same problem i flashed it by 4 files firmware |
I've had dozens of those, and the only solution i found is to trip knox i.e. by rooting phone or flashing twrp etc. |
I have a method for knox enrolment on A3's (2017) that doesnt require rooting or tripping knox. Same method doesnt work on later phone's though. ie, G960F |
https://www.youtube.com/watch?v=JV2mLpTie48 be careful to find the combination compatible with the firmware binary you have installed on your phone |
Take a binary combination compatible with the phone's firmware, extract the cm bin file with the 7zip software and rename it to tar format then flash the cim bin tar file with odin by selecting ap in odin in the video you will find the instructions Extract and flash cm bin tar combination file: https://www.youtube.com/watch?v=JV2mLpTie48 Then in the second part watch this video when you installed it by flashing the file cm bin tar for mdm lock reset: https://www.youtube.com/watch?time_c...&v=ecyCxc57a2g |
But MDM and knox enrolment are two completly different things. Knox enrollment is asigned to the IMEI of the the device, not its software. |
Just tried it on J530F, after flashing cm.bin updating OTA and flashing clean system it comes back as soon as you connect to wifi |
My best guess is that he has some connection with Samsung, like an acces to their servers or something? Also i think that changing IMEI might fix it, but I don't really have a phone that i could try it on. |
The guy i pay to remove knox enrolment 1 by 1 changes the serial number of the device and also changes the device to think it is dual sim. Dont know how he does it and how it is relevant. I believe knox enrolment is linked to the serial number of the device because of what the guy i know does to the devices. I could be wrong though |
I don't know if it's any helpful for You, but tripping knox also removes knox enrolment. Do You know if you change imei, and then change it back to the original one, it will remove knox enrolment or it will be back with original IMEI ? |
