Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
05-23-2015, 09:02 | #1 (permalink) |
Junior Member Join Date: Apr 2013 Location: Pakistan
Member: 1923761 Status: Offline Sonork: 100.1627585 Thanks Meter: 3 | SM-G925F this phone has been disabled by EE i have Samsung Galaxy S6 Edge G925F it shows "This Phone has been disabled by EE Please Help! |
The Following User Says Thank You to kbrainiac For This Useful Post: |
05-26-2015, 07:50 | #2 (permalink) | |
Freak Poster Join Date: Apr 2014 Location: Pakistan Age: 26
Member: 2164664 Status: Offline Sonork: 100.1654214 Thanks Meter: 119 | Quote:
1-Flash this persist wipe file 2-don't let it boot into android, take out battery! 3-put battery ,boot into recovery, 4-wipe data and cache partition 5-flash new firmware package (do not downgrade) 6-don't let it boot into android 7-wipe data and cache partition 8-power phone enjoy | |
05-27-2015, 11:13 | #3 (permalink) | |
Member: 1923761 Status: Offline Sonork: 100.1627585 Thanks Meter: 3 | EE disabled Quote:
05-27-2015, 16:04 | #5 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In a point from Universe! Age: 40
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | Quote:
just use google translate. The solution is for g920f and a500fu but is working also for other models. Regards! | |
05-28-2015, 15:41 | #6 (permalink) | |
Member: 1923761 Status: Offline Sonork: 100.1627585 Thanks Meter: 3 | EE disabled G925F Quote:
06-03-2015, 12:06 | #7 (permalink) |
Insane Poster Join Date: Jun 2008 Location: ROMANIA
Member: 801701 Status: Offline Thanks Meter: 42 | a500fu successful Hi, I managed to remove the EE lock from a500fu. First wipe data and cache, write non uk firmware, then boot into download mode again, do not let it boot into android, flash this custom recovery: https://yadi.sk/d/3lTTKnjsehGoF It's in chinese but you don't have to do anything, just plug the usb cable, adb mode will be enabled and device online (of course,install proper adb drivers first). I've found some interesting partitions: Code: lrwxrwxrwx 1 root root 21 May 8 2014 fsc -> /dev/block/mmcblk0p20 lrwxrwxrwx 1 root root 20 May 8 2014 fsg -> /dev/block/mmcblk0p9 lrwxrwxrwx 1 root root 21 May 8 2014 hidden -> /dev/block/mmcblk0p26 lrwxrwxrwx 1 root root 20 May 8 2014 modem -> /dev/block/mmcblk0p2 lrwxrwxrwx 1 root root 21 May 8 2014 modemst1 -> /dev/block/mmcblk0p14 lrwxrwxrwx 1 root root 21 May 8 2014 modemst2 -> /dev/block/mmcblk0p15 lrwxrwxrwx 1 root root 21 May 8 2014 pad -> /dev/block/mmcblk0p11 lrwxrwxrwx 1 root root 21 May 8 2014 param -> /dev/block/mmcblk0p12 lrwxrwxrwx 1 root root 21 May 8 2014 persdata -> /dev/block/mmcblk0p23 lrwxrwxrwx 1 root root 21 May 8 2014 persist -> /dev/block/mmcblk0p22 lrwxrwxrwx 1 root root 20 May 8 2014 qhee -> /dev/block/mmcblk0p8 lrwxrwxrwx 1 root root 20 May 8 2014 qsee -> /dev/block/mmcblk0p7 lrwxrwxrwx 1 root root 21 May 8 2014 recovery -> /dev/block/mmcblk0p17 lrwxrwxrwx 1 root root 20 May 8 2014 rpm -> /dev/block/mmcblk0p6 lrwxrwxrwx 1 root root 20 May 8 2014 sbl1 -> /dev/block/mmcblk0p3 lrwxrwxrwx 1 root root 21 May 8 2014 sec -> /dev/block/mmcblk0p10 lrwxrwxrwx 1 root root 21 May 8 2014 ssd -> /dev/block/mmcblk0p21 lrwxrwxrwx 1 root root 21 May 8 2014 system -> /dev/block/mmcblk0p24 lrwxrwxrwx 1 root root 21 May 8 2014 userdata -> /dev/block/mmcblk0p27 Code: adb shell mke2fs /dev/block/platform/7824900.sdhci/by-name/persdata mke2fs /dev/block/platform/7824900.sdhci/by-name/persist |
The Following User Says Thank You to v3ng3ance For This Useful Post: |
06-09-2015, 19:45 | #9 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: PAKISTAN Age: 52
Member: 48518 Status: Offline Sonork: 100.113013 Thanks Meter: 127 | Quote:
Solution of ur problem available here Br Xtreme | |
07-30-2015, 12:29 | #10 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 48
Member: 106154 Status: Offline Thanks Meter: 7 | Need working solution for G925F android 5.1.1! SM-G925F this phone has been disabled by EE Need working solution for G925F android 5.1.1! Need persist wipe file for G925F |
07-30-2015, 12:58 | #11 (permalink) | |
07-30-2015, 16:49 | #12 (permalink) |
Freak Poster Join Date: Feb 2006 Location: B D S Age: 40
Member: 237628 Status: Offline Sonork: 100.1668254 Thanks Meter: 140 | i have 2pc phone in my hand samsung s6 925f disable by EE i cannot solve this problem already tries some way, have any way to solve easy |
07-30-2015, 19:53 | #14 (permalink) | |
Member: 106154 Status: Offline Thanks Meter: 7 | Not working S6 EDGE 5.1.1 Quote: ~ $ ←[6nadb shell adb shell * daemon not running. starting it now on * daemon started successfully * error: device not found ~ $ ←[6nls /dev/block/platform ls /dev/block/platform 15570000.ufs ~ $ ←[6nmke2fs /dev/block/platform/155700 mke2fs /dev/block/platform/15570000.ufs/b /sbin/sh: mke2fs: Permission denied ~ $ ←[6ndd if=/dev/zero of=/dev/block/sda dd if=/dev/zero of=/dev/block/sda11 dd: /dev/block/sda11: Permission denied | |
07-30-2015, 20:10 | #15 (permalink) |
Member: 106154 Status: Offline Thanks Meter: 7 | FROM TWRP v2.8.7.1 C:\ADB>adb devices List of devices attached 03157df3db177a38 recovery C:\ADB>adb shell ~ $ ←[6ndd if=/dev/zero of=/dev/block/sda11 dd if=/dev/zero of=/dev/block/sda11 dd: /dev/block/sda11: Permission denied ~ $ ←[6n |
