Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
07-30-2015, 20:27 | #16 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 48
Member: 106154 Status: Offline Thanks Meter: 7 | From normal mode is start page shell@zerolte:/ $ dd if=/dev/zero of=/dev/block/sda11 dd if=/dev/zero of=/dev/block/sda11 dd: /dev/block/sda11: Permission denied 1|shell@zerolte:/ $ dd if=/dev/zero of=/dev/block/sda11 C:\ADB>adb shell * daemon not running. starting it now on port 5037 * * daemon started successfully * shell@zerolte:/ $ dd if=/dev/zero of=/dev/block/sda11 dd if=/dev/zero of=/dev/block/sda11 dd: /dev/block/sda11: Permission denied 1|shell@zerolte:/ $ info: 22:23:36 > Samsung SM-G925F READ INFO: START! 22:23:36 > Please power on phone and connect to usb in android debug mode! 22:23:36 > If phone ask to allow usb debuging please accept! 22:23:42 > KILLING ADB SERVER (IF RUNNING): OK! 22:23:44 > Searching for phone: OK! 22:23:52 > Reading info: OK! 22:23:55 > Checking root: OK! (ROOTED) 22:23:55 > BRAND: SAMSUNG 22:23:55 > MODEL: SM-G925F 22:23:55 > ZEROLTE / ZEROLTEXX 22:23:56 > HWID: SAMSUNGEXYNOS7420-10 22:23:56 > BOOT LOADER: G925FXXU2BOFJ 22:23:56 > COUNTRY CODE: RUSSIA / RU 22:23:56 > SALES CODE: SER 22:23:56 > VERSION: ANDROID 5.1.1 22:23:56 > BUILD LMY47X / G925FXXU2BOFJ 22:23:56 > G925FXXU2BOFJ / G925FOXE2BOF1 (PDA/CSC) 22:23:56 > FIRMWARE: ZEROLTEXX-USER / G925FXXU2BOFJ 22:23:56 > HARDWARE: MP 0.600 22:23:56 > KERNEL: 3.10.61-Alex-V_1.2 (gcc 4.9.3) 22:23:56 > PHONE SN: RF8G423F34K 22:23:56 > CPU TYPE: EXYNOS5 / SAMSUNG Exynos7420 22:23:56 > RIL MODEM: SHANNON333 22:23:56 > RIL VERSION: SAMSUNG RIL V3.0 22:23:56 > SIM STATUS: ABSENT 22:23:56 > Samsung SM-G925F READ INFO: END! Any solution ??? This Phone Is Disabled by EE ??? Last edited by master_gsm; 07-30-2015 at 20:32. |
08-31-2015, 21:58 | #19 (permalink) | |
No Life Poster Join Date: Jun 2015 Location: the planet earth
Member: 2406539 Status: Offline Thanks Meter: 101 | Quote:
how do you run adb shell from twrp?? i have been trying to run this command from pc but always get error, i can't find command prompt in twrp.. can you guide me how to run adb shell in twrp? | |
09-01-2015, 15:53 | #20 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 254271 Status: Offline Thanks Meter: 17 | It's not hard run https://www.androidfilehost.com/?fid=24052804347765202 in Odin uncheck auto reboot. When you get the blue reset on the screen hold volume down home power then when the screen shuts off switch to volume up but you have to be fast. If you don't get the teamwin blue and black boot screen your not in the right recovery and you need to start again but once you in there. I can't remember if it asks to modify or not I just tap the grey box to not modify. But if it didn't ask you just tap wipe then factory reset select back when complete plug phone in and let drivers install if no drive installs you can force the Google adb and select android adb driver. Bring up command prompt type adb shell then just be sure and type the commands again. Sent from my HTC One using Tapatalk |
09-30-2015, 19:04 | #21 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Pakistan/UAE/WorldWide Age: 26
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | Successfully wipe g925f ee disable lock I was successfully solved the ee disabled problem on S6 and S6 edge on 5.1.1 the solution is so tricky and after 10 days work I solve this problem so if you have any problem like "libco.so" error or "permission denied" error on twrp so please contact me on skype: unlockerplus "only message" Also contact me on sonork Last edited by shahsoft; 09-30-2015 at 22:26. |
10-01-2015, 14:05 | #22 (permalink) | |
No Life Poster Join Date: Feb 2004 Location: Bulgaria Age: 57
Member: 52180 Status: Offline Thanks Meter: 47 | Quote:
What is the decision? | |
10-01-2015, 18:08 | #24 (permalink) |
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | Change twrp and change what you want but fact is that the 5.1.1 is new security but can be patched by a long trick sent from nokia 3310 |
10-06-2015, 00:41 | #28 (permalink) |
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | This is our hard working and a long time to solve this problem. Now people was very clever after frp lock. You dont know what happen on frp lock solution people makes lot of money for that and I am the one who paid for this. after that ......?? sent from nokia 3310 |
10-11-2015, 07:17 | #29 (permalink) | |
Freak Poster Join Date: Jul 2009
Member: 1085379 Status: Offline Thanks Meter: 65 | Quote:
Sent from my ONE A2001 using Tapatalk | |
10-17-2015, 11:13 | #30 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2474124 Status: Offline Thanks Meter: 0 | hello. I have a galaxy s6 edge with the same problem. I ran into custom recovery but when I try to write those adb commands it says permission denied. I don't know what to do anymore. It is very annoying. Can anyone help me? I`d appreciate. I have the beer ready! |
