Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
01-17-2020, 13:28 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | samsung note 8 mdm problem i have here samsung note 8 it with mdm lock sadly the phone has password no download mode and only i can do is to put it in recovery and also you cannot do anything there the only function that work is to power off hehe i have done so far is 300k resistor software and actual resistor still no download mode..it is detected as modem when i connect it to pc |
01-20-2020, 19:36 | #2 (permalink) |
Insane Poster Join Date: Jan 2006
Member: 219402 Status: Offline Thanks Meter: 12 | I've done a samsung verizon tablet, passworded, no download mode, recovery mode doesn't allow reset. like FRP bypass, install shortcut maker or similar apps before it goes through the Knox configuration. then *while* Knox is downloading and installing, go in there and disable anything you think related to Knox. In my case, I also disable some Verizon stuff too. then the Knox process might halt, then you might be able to boot into download mode. once you're in download mode, flash a combination, boot up, and boot download mode again, flash stock, without cache, trial and error a few times, as long as it can boot, it will boot directly into the home screen and bypass the Knox step. and the thing is unlocked. |
The Following User Says Thank You to crump For This Useful Post: |
