Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
![]() | #1 (permalink) |
Moderator ![]() Join Date: Nov 2009 Location: €urope Age: 42
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,165 | [TWRP][ROOT][DRK FIXED] Samsung S6 / S6 Edge on Android 7.0 Nougat ![]() Download ==> [TWRP][ROOT][DRK FIXED] Samsung S6-S6 Edge on Android 7.0 Nougat Download ==> Super User Rar pass:- gsmhosting Install TWRP Recovery In Samsung Galaxy S6 / S6 Edge Nougat. Code: Unzip the Odin 3.XX.X .zip file and run/open Odin3 v3.XX.X.exe file from the extracted files on your PC. Make sure you’ve downloaded a Odin flash-able TWRP recovery .tar file compatible for your device. Enable OEM unlock: (If applicable) Code: Go to Settings » About phone » and tap Build number seven times to enable Developer options. Go back to main Settings page, scroll to bottom and select Developer options from there. Under Developer options, look for Enable OEM unlock checkbox/toggle and enable it. Boot your device into Download mode: Code: Switch off your device. Press and hold “Home + Power + Volume down” buttons for a few seconds until you see a warning screen. Press Volume Up on the warning screen to accept it and boot into Download mode. Once your device is in download mode, connect it to the PC with a USB cable. The Odin window on PC should detect the device and show an “Added!!” message. Now click on the AP tab on Odin window and select the TWRP recovery .tar file that you downloaded for your device. Note: DON’T play with any other options on the screen. You’re only required to connect your device and select the TWRP recovery .tar file in the AP tab. Click the Start button on Odin and wait for it to finish the process. Once it has finished successfully, you’ll see a pass message on the Odin screen. Your device will automatically reboot when Odin is done flashing. You can then disconnect your device. How to boot into TWRP recovery on a Samsung Galaxy device Code: Switch off your device. Press and hold “Home + Power + Volume Up” buttons for a few seconds and as soon as you see your device’ logo on-screen, Release three buttons altogether. Your device will boot into TWRP recovery. Root Guide Code: Download SuperSU on your phone. Make sure TWRP is installed. Turn off the phone. Press the volume up, home and power buttons at the same time to go to recovery mode. While in recovery, go to “Install” and navigate to where the SuperSU file is located. Select the file and swipe to flash it. Wait for the phone to flash the file. Now go back and reboot your phone. Wait for it to boot up. If the SuperSU app isn’t shown on the app drawer, go to the Play Store and download the latest version. Now you have rooted your Nougat Galaxy S6 / S6 Edge. After root you can Fixed DRK Problem by install Magisk apps Code: Install Magisk Manager from the Google Play store when your device reboots. Launch the app and Install/Upgrade Magisk as and if prompted and reboot. ==> Source XDA
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 02-18-2018 at 06:38. Reason: Information update |
The Following 7 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
![]() | #3 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,165 | Hi, Rar password:- gsmhosting
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following 3 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
![]() | #5 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2015 Location: Pakistan
Member: 2475109 Status: Offline Thanks Meter: 140 | Tested Solution on Samsung galaxy S6 Edge Root on 7.0 Video Tutorial Here Last edited by ...:::::NP™:::::...; 09-07-2017 at 20:56. Reason: Youtube link correction |
![]() | #6 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2008 Location: GSM,Pakistan
Member: 811049 Status: Offline Thanks Meter: 106 | Quote:
flash comb.file enable adb. connect uart port press repair drk button eft dongle and done now reflash desire firmware and done. | |
