Universal Samsung Galaxy s6 s7 note 5 note 7 FRP bypass for all Samsung devices Universal Samsung FRP Bypass http://i66.tinypic.com/2rm6r9l.jpg As per users report, Make sure that all Protected Smart card Softwares are disconnected While using this software, because this might Block Or Deactivate the smart-card. Here are the steps to remove factory reset protection / Google previously synced account lock from your Samsung device. 1.Download and installRealTerm program 2.Download and copy com.rootjunky.frpbypass-1.0.apk to the device micro sdcard or download once into the device. 3.Start phone and connect to WIFI also plug into the computer with your usb cable. 4.Start RealTerm on your pc and under pisplay check the box HALF DUPLEX 5.Right click on my computer and select manage once it opens click device manager then modems 6.Under modems you should see a Samsung device. right click it then select properties 7.Once the properties window opens select modem tab and see what port it is on like com5 for an example 8.Now that you know the com port number close all device manager windows and open RealTerm again 9.Under the ports tab in RealTerm enter your port number then click change. 10.Next, click the send tab. you will need to send these two commands with the Send ASCII button 11.First at+creg?\r\n 12.Then atd1234;\r\n 13.Look at your phone and the dailer will pop up. 14.Now watch the video below to see the rest of the steps and please comment below on your success or failures. thanks NOTE: If you dont have a SDcard and are getting the sparse ERROR in es file explorer then you can buy a OTG flash drive and load the FRPbypass.apk to it from your computer then plug it into the phone. once plugged in navigate to it in es file explorer and install the frp bypass app that way. You can also put this address into your ES file Explorer app https://www.androidfilehost.com/?fid=24665542585483676 Here is a video Tutorial Another Video: http://forum.gsmhosting.com/vbb/f777...ethod-2124681/ Tested devices: Galaxy s6 s7 note 5 note 7 J 5 2016 J710F |2016| Android 6.0.1 A310f A510f J700T1 Versión: 6.0.1 J320F/DS j700 2016 j710gn j710FN G935fxxu1apc8 g935k g935w8 ... Source:RootJunky.com | Learning how to hack your Android device |
this step working all samsung mobile sir |
U can test if other models are working! |
WoooooW working 100% now i can remove google account on samsung J 5 2016:cool: thanks bro :D:D |
not working S5 G900f 6.0.1 |
Very good explained thx very good video very clearly. greetings from Belgium ps it works samsung S7 |
Hi to all, Information to all. Please when use this programme Deattach all boxes. Otherwise Boxes card will get demage. Becarefull Thanks Br, Raja |
FRP |Google Account| Removed Successfully on J710F |2016| Android 6.0.1. Thanks To All. |
dont work j700m 6.0.1 after command at no see dial pop up in my phone |
World weakest protect. Like icloud upgrade need. |
it doesn't work on j200m |
superb one (y) successfully unlocked FRP in A310f.. |
Works flawlessly with A510f |
Please post your tested devices here to update the original thread. Post model and version. |
