Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
07-12-2013, 09:42 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Patch unlock = non pro
Member: 323137 Status: Offline Thanks Meter: 235 | Emma Xperia Flash tool To install the flash tool, follow the steps below: Download the Flash tool for Xperia devices. http://dl-developer.sonymobile.com/t...r_Xperia_3.zip Unzip the file you downloaded and place it somewhere on your computer. In the unzipped folder, run Emma.exe. During the installation, make sure you remember the installation path: Default path in Windows 64 bit is: C:\Program Files (x86)\Sony Mobile\Emma\ Default path in Windows 32 bit is: C:\Program Files\Sony Mobile\Emma\ Copy the Customization.ini file. You find it in the Flash_tool_for_Xperia_X.zip. Paste the Customization.ini file into the installation folder. The installation folder is the folder named Emma in the installation path examples on point 3.1 and 3.2 above. Click Start > All programs > Sony Mobile > Emma (if you used the default installation path from step 3 above) to start the flash tool When you have installed the flash tool for Xperia, you can flash standard Sony software on your unlocked Xperia device. Note! When you flash software onto your device, your user data and content will be erased. Make sure to properly back up all information. This is how you flash software on your phone: 1. Computer: Open Emma from the Start menu of your computer. 2. Connect a USB cable to your computer. 3. Phone: Turn off your phone. 4. Connect your phone to the USB cable while holding the flash key (for example Volume down). The flash key varies between models. For a complete key mapping, see the list in the bottom of this thread. Screenshot showing the flash tool when a phone is connected. 5. Computer: Select the software you want to flash in the Service list. The tool automatically detects the phone model and lists available software versions, which are called Services in this flash tool. 6. Click on Apply Service. The phone will now be flashed. 7. Phone: When you have flashed your device, you can disconnect your phone from the computer. The first time you start your device after you have flashed it, the boot-up might take a little longer than normal. Xperia Tablet Z (SGP321 and SGP311) volume down Xperia go (ST27i) back Xperia neo V (MT11i) volume down Xperia ray (ST18i) volume down Xperia P (LT22i) volume down Xperia ZL (C6503) volume down Xperia Z (C6603) volume down Xperia PLAY (R800i) back Xperia E dual (C1605) volume down Xperia E (C1505) volume down Xperia T (LT30p) volume down Xperia S (LT26i) volume down Xperia arc (LT15i) back Xperia arc S (LT18i) back |
The Following User Says Thank You to reactos For This Useful Post: |
08-30-2013, 15:05 | #3 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: portugal Age: 46
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | Quote:
...only unlocket fones?? cheers | |
The Following User Says Thank You to carlos32 For This Useful Post: |
09-30-2013, 05:25 | #6 (permalink) |
Freak Poster Join Date: Mar 2012
Member: 1740134 Status: Offline Thanks Meter: 52 | New link for Emma flash tool. http://dl-developer.sonymobile.com/t...r_Xperia_4.zip |
The Following 2 Users Say Thank You to nokiaa2 For This Useful Post: |
04-23-2014, 07:17 | #10 (permalink) |
Registered User Join Date: May 2008 Location: ...::IsLam::... Age: 39
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | Which Model Suported........... |
The Following User Says Thank You to .....::::GsmAdeel:::::..... For This Useful Post: |
11-17-2014, 11:59 | #12 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Green Forest
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | no need u/p just do it Default path in Windows 64 bit is: C:\Program Files (x86)\Sony Mobile\Emma\ Default path in Windows 32 bit is: C:\Program Files\Sony Mobile\Emma\ Copy the Customization.ini file. You find it in the Flash_tool_for_Xperia_X.zip. Paste the Customization.ini file into the installation folder. The installation folder is the folder named Emma in the installation path examples on point 3.1 and 3.2 above. Click Start > All programs > Sony Mobile > Emma (if you used the default installation path from step 3 above) to start the flash tool |
02-13-2015, 11:14 | #14 (permalink) | |
Major Poster Join Date: Mar 2010 Location: indonesia
Member: 1262626 Status: Offline Thanks Meter: 9 | Quote:
thanks for advance....very usefull and no need username and pasword | |
