Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
12-06-2017, 07:35 | #1 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2689353 Status: Offline Thanks Meter: 4 | Fix "factory startup service please wait for power off button" + red screen Sony XA U |
12-09-2017, 17:36 | #6 (permalink) |
Freak Poster Join Date: Apr 2001 Location: EVRYWERE
Member: 4365 Status: Offline Thanks Meter: 39 | try method 2 - solutions to this "problem" : charge battery to at least 65%, reflash phone fully ( app,fsp,eLabel,CDF ), put phone on flat surface,power on it and do not touch, until "power off" button appears OR after flashing, write next script, this will signal factory startup service that it is successfully completed all steps Code: tawrite:000208B350000000 OR disable factory startup service application in phone using standard android ways. Last edited by wgmmmx1; 12-10-2017 at 17:40. |
The Following 7 Users Say Thank You to naderhacker For This Useful Post: |
12-10-2017, 10:38 | #7 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,129 | You can solve via by writing script which post before , charged battery wont work for all models , before full flash just write the script and check |
01-25-2018, 14:31 | #9 (permalink) | |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | Quote:
07-03-2018, 21:03 | #11 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,787 | Quote:
Flashed yesterday some older xperia, battery 17%, powered on normally, when showed factory service bla bla, waited until big POWER OFF text appeared, clicked on it, phone powered off. After power on, all works normal. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
07-05-2018, 07:17 | #13 (permalink) | |
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,129 | Quote:
hello sir some latest xperia phones after flash you need Morethen 50% to run startup apps , best regrads | |
07-06-2018, 01:33 | #14 (permalink) | |
even with low battery. (Z3, Z3c, E5, etc) Some of them worked with, some without script writing ... b.r. Alex
01-04-2022, 11:17 | #15 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 227 | I had to use a script: tawrite:000208B350000000 Anti theft service and factory startup service they disturbed each other. Now that I managed to turn off anti theft, i want to switch back factory startup service to finish your thing. Is there a sprict that cancels this: tawrite:000208B350000000 ? (I know SW doesn't change it back to its original state.) |
