Help plz failed error 1 Attachment(s) HI PLZ HELP I FLASH SONY F3112 FOR PETREN REMOVE BUT AFTER FLASH PHONE FINISH SETUP AND SHOWS FAILED 2227.55 00 00 00 228.01 03 04 08 0A 0C 229.04 08 0C 01 030 I FLASH ON SETOOL AFTER I TRY TO REPAIR IN Xperia Companion REPAIR ID DONE BUT PROBLEM IS SAME [ATTACH]:confused:[/ATTACH] |
Try to flash with Flashtool and in Firmware selector tick all options under the “Wipe” pane. http://www.xperiablog.net/2016/03/12...erifirm-guide/ |
same problem again not fixed |
Try this workaround, you must disable the following system application: com.sonyericsson.startupflagservice 2 https://www.youtube.com/watch?v=W-bOYFLRhPQ&t=0s https://talk.sonymobile.com/t5/Xperi...-2/td-p/860449 |
i have tested one of this problem.... solution flash via setool using this 2 file at the support APP-SW_Tuba_GLOBALDS-LTE1D_33.2.B.3.81_1300-9504_S1-SW-LIVE-CF2A-PID1-0005-MBR FSP_Tuba_Customized-SA_GENERIC_33.2.B.3.81_1302-4393_R5A_S1-SW-LIVE-CF2A-PID1-0005-MMC problem will solved without error.... |
same problem help me sony f3311_xperia_e5 |
if there is no google account update your phone with Xperia Companion to last version problem solved 100 % |
sony f3311 factory startup service solved pro solvd with this file ver 37.0.A.2.108 downloded from setool sport... APP-SW_Bassoon_GLOBAL-LTE1A_37.0.A.2.108_1301-9750_S1-SW-LIVE-8C38-PID1-0005-MBR FSP_Bassoon_Customized-SA_GENERIC_37.0.A.2.108_1306-1005_R1A_S1-SW-LIVE-8C38-PID1-0005-MMC |
it didnt work on G3121 device.. still failed.. |
thanks ..Ali Abbas.. APP-SW_Bassoon_GLOBAL-LTE1A_37.0.A.2.108_1301-9750_S1-SW-LIVE-8C38-PID1-0005-MBR FSP_Bassoon_Customized-SA_GENERIC_37.0.A.2.108_1306-1005_R1A_S1-SW-LIVE-8C38-PID1-0005-MMC workkkkkkk |
