Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
02-13-2013, 21:22 | #2 (permalink) |
Insane Poster Join Date: Feb 2013
Member: 1882718 Status: Offline Thanks Meter: 6 | Download plasma tool from the sticky, find any firmware for your phone. For example this one: https://rapidshare.com/files/2254894...1246-9107_.ftf Open the firmware with PlasmaSTool and tip userdata.sin and cache.sin only, no need full flash. Connect phone in flash mode and click Flash. I did it to my phones, works perfect. It will also delete all user data and clear cache, so the phone will be like new (empty). |
02-16-2013, 18:44 | #3 (permalink) |
Major Poster Join Date: Feb 2013 Location: Chennai Age: 31
Member: 1883363 Status: Offline Thanks Meter: 7 | Download plasma tool from the sticky, find any firmware for your phone. For example this one: https://rapidshare.com/files/2254894...1246-9107_.ftf Open the firmware with PlasmaSTool and tip userdata.sin and cache.sin only, no need full flash. Connect phone in flash mode and click Flash. |
07-30-2013, 06:45 | #5 (permalink) |
Insane Poster Join Date: Oct 2009
Member: 1149197 Status: Offline Sonork: prateet Thanks Meter: 43 | Sony Experia MT25i Hard Reset Or Pattern Lock Try This Sony Experia MT25i Hard Reset Or Pattern Lock Solution ~ *********.com |
The Following 2 Users Say Thank You to prateet For This Useful Post: |
08-03-2013, 10:56 | #6 (permalink) |
Freak Poster Join Date: Aug 2007 Location: punjab
Member: 564102 Status: Offline Thanks Meter: 8 | sony mt25i hard reset on mobile phone and click on emergency call then type code *#*#7378423#*#* click on customiztion setting and then reset customization after reboot set all reset done |
The Following 5 Users Say Thank You to DALVINDER For This Useful Post: |
05-03-2014, 13:38 | #7 (permalink) |
Major Poster Join Date: Jul 2013
Member: 1985308 Status: Offline Thanks Meter: 7 | sony mt25i hard reset on mobile phone and click on emergency call then type code *#*#7378423#*#* click on customiztion setting and then reset customization after reboot set all reset done IT WORKS THANKS IN ADVANCE |
The Following User Says Thank You to LIONSON For This Useful Post: |
03-20-2015, 13:31 | #9 (permalink) |
Junior Member Join Date: Dec 2014 Location: Azerbaijan
Member: 2317848 Status: Offline Thanks Meter: 1 | Resetting the Xperia NEO MT15i phone Resetting the phone You can reset your phone to its original settings, with or without deleting all of your personal data. It is possible to reset the phone to the state it was in before you first turned it on. But before you perform a reset, make sure to back up any important data saved on your phone. To reset the phone 1. From your Home screen, tap Application icon (center icon bottom of the screen). 2. Find and tap Settings > Privacy. 3. Tap Factory data reset. 4. To erase not only internal storage but also other user data such as pictures and music, mark the Erase SD card checkbox. 5. Tap Reset phone. 6. To confirm, tap Erase everything. |
