Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
05-18-2016, 10:10 | #1 (permalink) |
Junior Member Join Date: Jun 2015 Location: Dhaka, Bangladesh Age: 30
Member: 2417044 Status: Offline Thanks Meter: 100 | Sony Xperia z3 D6603 Dead Boot Repair .... D6603 Dead After Flash By Sony ftf Flash tool Flash fully complete But Device still off and no response sometimes only Connect With pc a Boot Repair Driver Kindly Can You Help me?? I need Your Valuable Help Thanks in Advance |
05-23-2016, 15:01 | #2 (permalink) |
Junior Member Join Date: Nov 2015 Location: Brazil Age: 30
Member: 2488197 Status: Offline Thanks Meter: 0 | The phone literally is not showing any signal of life or at least the led indicator lights up? In any case, have you tryied holding the power for about 30 seconds till the phone vibrates 3 times to make shure its turned off? Maybe your volume flat is damaged and the phone is booting directly to flash mode again, I had this problem before and the solution was replacing the main flex. The phone was working fine before you flashed the ftf? |
