Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 09-23-2015, 09:07   #1 (permalink)
..::CHAIN::..'s Avatar
Member: 1753928
Sonork: 100.1615906
Thanks Meter: 2,318
Cool [SOLVED]Sony Xperia Z1 C6902 Lock Remove Ftf Tested Inside
Hello,
I Check Many Guys Are Looking For This Ftf From a Long Time!! So Now Searching Ends Here.. Good Luck ..........
Regards,
____________
The Following 19 Users Say Thank You to ..::CHAIN::.. For This Useful Post:
Old 11-01-2015, 16:41   #2 (permalink)
charan orissa's Avatar
Member: 1524542
Sonork: 100.1607125
Thanks Meter: 108
my phone is done .....realy its 100% working unlock ftf
Old 11-01-2015, 20:11   #3 (permalink)
Member: 2385655
Thanks Meter: 99
Exclamation [SOLVED]Sony Xperia Z1 C6902 Lock Remove Ftf Tested Inside
how to use soft setool box pc sute
Old 12-02-2016, 15:00   #4 (permalink)
Crazy Poster
Member: 874424
Thanks Meter: 15
My phone done with hlp of chain bro gd bless u bro thanks!
Old 05-14-2017, 13:20   #5 (permalink)
Member: 2695070
Thanks Meter: 7
not showing this file in flashtool
Old 05-14-2017, 13:38   #6 (permalink)
Member: 2596967
Thanks Meter: 9
Use Old Versin Flashtool
Old 06-02-2017, 18:31   #7 (permalink)
MYUNLOCKING's Avatar
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
can i flash this file on so-01f from japan?
Old 06-07-2017, 10:24   #8 (permalink)
RIZU007's Avatar
Member: 2559619
Sonork: 100.1672420
Thanks Meter: 205
Originally Posted by ..::chain::.. View Post
hello,
i check many guys are looking for this ftf from a long time!! So now searching ends here.. Good luck ..........
c6902 lock remove ftf
regards,
____________
working perfect pattern remove done
great job
Old 11-02-2017, 10:44   #9 (permalink)
teletalk's Avatar
Member: 926215
Sonork: 100.1650776
Thanks Meter: 95
unfortunately its not working for me .....when try to flash this file using flashtool flashing start but .......not reach at end ......mean stuck in process so i heard its a 106mb file but yours is a only 797 kb so i confused
Old 12-10-2017, 16:18   #10 (permalink)
Member: 2493870
Thanks Meter: 16
Originally Posted by ..::CHAIN::.. View Post
Hello,
Regards,
____________
thank You very much , it is work for me {{Xperia Z1-C6902}}
Old 12-10-2017, 17:51   #11 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Or just flash phone like is tutorial here and will be unlocked without any problem. New flashtool got additional option to hard reset phone after flash to reset phone code too.
SONY Xperia Z1 C6903 - Frequently Asked Questions about resetting your device - HardReset.info
__________________
Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums!
To get Instant help use "search" & follow "sticky thread"..!!!
By respecting/following forum rules,You will be respected .!
Old 06-22-2020, 17:05   #12 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 326
can unlock SONY Xperia Z1 C6903 network lock?
RUNNING v 1.1436/01.14/UNI
CARD SERIAL ........
USBFLASH DRIVER VERSION 02.02.00.05
SIGNED MODE (USING SERVER)
CFG:101000000000
PLEASE ATTACH TURNED OFF PHONE NOW
PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ...
\\.\EPIUSB1
\\?\USB#VID_0FCE&PID_ADDE#5&2b206c2b&0 &4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
RUNNING S1_BOOT VER "S1_Boot_MSM8974_Rhine1.3.1_LA1.04_16"
ACTIVE_COMP_AID : 0004
HWCONF_AID : 0004
LOADER_AID : 0004
BOOT_AID : 0004
[ llcomm: 00080000,00080000 ]
DEVICE ID: 04478AEC
FLASH ID: "0015/01000001"
LOADER VERSION: LOADER_RELEASE_MSM8974_32_AID_4
PHONE IMEI : 35809305506466
MODEL (from GDFS): C6903
SOFTWARE VERSION: 1274-8313_14.6.A.1.236
CUSTOM VERSION: 1276-4318_R4D
FILESYSTEM VERSION: EURO-LTE_14.6.A.1.236
Network LOCK : 00101-* [ 0/10 ]
Network LOCK : 44050-* [ 0/10 ]
SERIAL NO: CB51264D4S
SECURITY UNITS BACKUP CREATED
Elapsed: 3 seconds
Page generated in 0.25986 seconds with 8 queries
