X10 Flash Tool - Firmwares X10 Flash Tool http://www.mediafire.com/imgbnc.php/...4a1ef5965g.jpg Download: Executeable: http://www-stud.uni-due.de/~sfanmakr...0Flash-2.1.zip If the Firmware package is missing the loader.sin you can take the loader.sin from my loader-collection and copy it into every firmware package you have! Multiupload.com - upload your files to multiple file hosting sites! Older NonGui-Version (if you have issues with GUI Version): http://www-stud.uni-due.de/~sfanmakr...2.1-nonGui.zip Source: http://www-stud.uni-due.de/~sfanmakr...sh-2.1-src.zip Update (14.11.2010): GUI Version (thanks to eodille) . See HowTo @the End of the Thread Update (5.11.2010): - Fixed Xperia detection! Update (3.11.2010): - Optimized a little - Catched Openchannel Error Updates (2.11.2010): - fixed 32Bit Java Error on 64Bit Systems - Added Loaders - Added wipe Userdata option - Compressed Output - Small Bugfix Todo: - Optimize (always :P) - Add 1.6 Firmware compability Best Regards Bin4ry HOWTO GUI: FLASHING: Just add a new folder to the MAIN FOLDER of Flashtool which contains the firmware. Now press Flash. The Tool will show you all firmwares which are stored in the FlasherFolder. Before you press "OK" connect your Phone in flashmode and THEN PRESS OK! Be also sure that you have the loader.sin in the package! IF not take it from my download link at the beginning of this post! The flashing should begin now! ROOT: Press the Root button and connect your phone with Debug mode activated! The Tool will install z4Root.apk. z4root.apk is located in custom/root/ folder. CUSTOMIZE: This function will install all apks which are located in /custom/apps/ Clean: This function will CLEAN ALL FILES WHICH ARE NAMED IN THE 2 Files in the directory : /custom/clean/ You can uncomment files with "#" PROBLEMS: If you see endless dots and "Searching for Xperia...." message, your phone reboots from flashing mode to regular one itself, most likely your phone is invisible for the flasher for some reason (wrong drivers, drivers conflict or something like this). To fix this problem you have some options: try to flash at another computer try to flash at clean Windows installation reinstall flashing drivers Tools you need for those methods: Flasher (in the first message) Firmware you want to flash (in the first message or other threads for specific FWs) Drivers (zSHARE - USBFlash_driver.rar (c) kindred7) manage drivers Program USBDeview (I had similar problem (post # 671). It seems to me, there is a drivers problem - wrong driver set or drivers conflict. There are some options: try to flash at another computer try to flash at clean Windows reinstall drivers Tools you need for those methods: Flasher (in the first message) Firmware you want to flash (in the first message or other threads for specific FWs) Drivers (zSHARE - USBFlash_driver.rar (c) kindred7) manage drivers Program USBDeview (http://forum.xda-developers.com/atta...4&d=1289579377 (c) XperiaX10iUser) And, as usual, some good luck. (c) XperiaX10iUser) And, as usual, some good luck. Find Firmware #2 post |
Download Firmware Download Firmware: X10i: Multiupload.com - upload your files to multiple file hosting sites! Nordic Thanks to imugur and Reb0rn Multiupload.com - upload your files to multiple file hosting sites! GERMAN Multiupload.com - upload your files to multiple file hosting sites! CH (thanks to pippolino) X10a: Multiupload.com - upload your files to multiple file hosting sites! ROGERS (thanks to henh) Multiupload.com - upload your files to multiple file hosting sites! GENERIC (thanks to BluechipJ & batman112) Put the extracted files into the new "firmware" Folder and run the X10flash.bat SO-01: Multiupload.com - upload your files to multiple file hosting sites! DOCOMO (thanks to indigomode) A Big Thanks to Bin4ry |
Mr supporta i have X10i need to change firmware to arabic i found x10A think there is arabic can i use it? Thanks |
@ kadricom Nope, X10a means Latin American version of X10. for lang info. Arabic not released for X10 yet. Even no one have solution right now. |
brother flasher link not working :( fix it pls Quote:
br: 2net2 |
good job bro iwant to know there is french also? |
